1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Timestamping Confusion
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sat, 12 Dec 2020 14:24:45 +0100
On Fri, 11 Dec 2020 at 22:33, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Thanks for the comments Michael, when you are dealing with hundreds of waveform records and the timestamps are being taken when each record is processed (I would assume these would all be off by some delay if multiple softIOCs are running) do you then just have a master time waveform to lineup all your other signals to t0?  It seems the digitizer would have a time stamp of t0 for all of its signals but the epics records would not all align at the same timestamp since each one isn't processed at t0 to be timestamped.
The EPICS Device Support needs to know the timestamp t0 (preferably sent with the data by the digitizer) and write it to each record's timestamp when it updates the record.
In that case, by configuring their TSE to -2, all waveform records can use the digitizer timestamp. That timestamp can even be forwarded (using TSEL) through post-processing chains, so that processed data may still use the timestamp that the digitizer sent with the raw data at the beginning of the chain.
Cheers,
~Ralph
RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Re: Timestamping Confusion Michael Davidsaver via Tech-talk
Prev: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: A tribute to our benefactors Bob Dalesio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
