1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Why FQDN is sometimes required in the IOC access list?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 16 Dec 2020 10:53:01 +0100
On Wed, 16 Dec 2020 at 10:09, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
  1.  When are FQDNs necessary for the access file?
From the documentation (AppDev Guide):
[...] To match, a host name must match the host name read by the CA client library running on the client machine; both names are converted to lower case before comparison however.
The name that a client uses depends on the name resolution service configuration on the client machine. If your client machines use different configurations, the requirements for their mention in the AS configuration file may differ.
One way to handle that uncertainty and make the IOC side more robust is to always put the simple name in addition to the fully qualified name in the AS configuration.
Cheers,
~Ralph
Why FQDN is sometimes required in the IOC access list? Abdalla Ahmad via Tech-talk
Prev: Why FQDN is sometimes required in the IOC access list? Abdalla Ahmad via Tech-talk
Next: WITec alpha300R VIS Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
