1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: DBE_PROPERTY in CS-Studio Phoebus
From: "Roehrig, Christian via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Jan 2021 22:24:05 +0000
Thank you Kay, it works beautifully.
Chris
Christian Roehrig
Principal Controls Engineer
Accelerator Systems Division
Argonne National Laboratory
Office: 630-252-7278
Cell: 630-327-6855
Date: Tuesday, January 12, 2021 at 3:58 PM
To: [email protected] <[email protected]>, Roehrig, Christian <[email protected]>
Hi:
For the most recent version of CS-Studio, i.e. the one that no longer depends on Eclipse, https://github.com/controlSystemStudio/phoebus/, the preference settings https://control-system-studio.readthedocs.io/en/latest/preferences.html that control support for DBE_PROPERTY are described in  https://control-system-studio.readthedocs.io/en/latest/preference_properties.html#pv-ca :
# Is the DBE_PROPERTY subscription supported
# to monitor for changes in units, limits etc?
org.phoebus.pv.ca/dbe_property_supported=false
For the older Eclipse-based CS-Studio, the corresponding setting should be "diirt.ca.dbe.property.supported" as listed in https://github.com/ControlSystemStudio/cs-studio/blob/master/core/diirt/diirt-plugins/org.csstudio.diirt.util.core.preferences/preferences.ini
-Kay
From: Tech-talk <[email protected]> on behalf of Roehrig, Christian via Tech-talk <[email protected]>
Sent: Tuesday, January 12, 2021 12:42 PM
Subject: [EXTERNAL] DBE_PROPERTY in CS-Studio Phoebus
Hello,
     I am using CS-Studio Phoebus, version 4.6.3 with epics version 7.0.4.  I have an asynPortDriver that will change the enum strings of an mbbo record based on the value of a different mbbo record.  When trying to get the combo box values to properly reflect the new string values, I ran across this message from 2016 regarding CS-Studio version 4.2.x.
https://epics.anl.gov/tech-talk/2016/msg01005.php
While it discusses exactly what I want to happen, the steps do not seem to match the version of CS-Studio that I am using.  Does anyone have updated instructions that I can follow?
Chris
Christian Roehrig
Cell: 630-327-6855
DBE_PROPERTY in CS-Studio Phoebus Roehrig, Christian via Tech-talk
Re: DBE_PROPERTY in CS-Studio Phoebus Kasemir, Kay via Tech-talk
Prev: Re: DBE_PROPERTY in CS-Studio Phoebus Kasemir, Kay via Tech-talk
Next: Re: PvaClientMultiChannel CPP: multiGet get() looks like to interfere with multiMonitor waitEvent() Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Error building asyn-R4-41 on Manjaro David Vine via Tech-talk
