I assume that, for each channel, you are calling
pvaClientChannel->connect
Instead , for each channel, call
pvaClientChannel->issueConnect
than , for each channel, call
pvaClientChannel->waitConnect
You can also just check connection status instead of calling waitConnect
Hope this helps.
Marty Kraimer
On 1/25/21 2:00 PM, Axel Terfloth via Tech-talk wrote:
Hello,
i’m new to EPICS and take a closer look at it for evaluation purpose. To obtain a better understanding I started to dig deeper by implementing some tests which are based on the C++ examples. From a functional point of view everything I tried works nicely so far. Also the performance is generally very good in most of my test scenarios. Nevertheless one issue i came across is the time required for connecting to a channel via PVA. In this scenario I set up 4000 process variables and implement one client which implements high frequency put and get access to a quarter (1000) of these proces variables. On my machine (which runs all processes for now) if takes about 250ms for a single channel connection. Once all channels are connected is really fast. Nevertheless connecting 1000 pvs takes more than 6 minutes. I currently connect channel by channel using the PvaClient API in my tests. Is there a more efficient way to connect to a large set of channels? I would appreciate any hint.
Best regards,
Axel Terfloth
- Channel connection performance Axel Terfloth via Tech-talk
Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
<2021>
2025
2026
Re: Channel connection performance Michael Davidsaver via Tech-talk
<2021>
2025
2026
