1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance bug report
From: Michael Davidsaver via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 1 Feb 2021 08:48:43 -0800
On 2/1/21 7:08 AM, lup--- via Tech-talk wrote:
> http://192.168.116.213:17665/mgmt/ui/pvdetails.html?pv=HALF%3ABD%3ANetIO%3ARelay%3ASetAll <http://192.168.116.213:17665/mgmt/ui/pvdetails.html?pv=HALF%3ABD%3ANetIO%3ARelay%3ASetAll>
>     when I point on details of a PV, it gives a good link as ahead.
> http://localhost:17668/retrieval/ui/viewer/archViewer.html?pv=HALF%3ABD%3ANetIO%3ARelay%3ASetAll <http://localhost:17668/retrieval/ui/viewer/archViewer.html?pv=HALF%3ABD%3ANetIO%3ARelay%3ASetAll>
>    but quick chart gives this (localhost in the link).
> manually change the link, it can display the appliance viewer:
I suspect that you have 'localhost' appearing in the appliances.xml config file,
and that replacing this with '192.168.116.213' will help.
see also:
https://slacmshankar.github.io/epicsarchiver_docs/installguide.html
https://github.com/slacmshankar/epicsarchiverap/wiki/setup_rhel7_rpms#prepare-configuration
Archiver Appliance bug report lup--- via Tech-talk
Prev: Re: [EXTERNAL] EPICS Codeathon: March 8 to March 12 Hartman, Steven via Tech-talk
Next: Question about http communication by stream device lzf neu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Archiver Appliance bug report lup--- via Tech-talk
