Subject: Re: setcap and nosuid
From: "Siddons, David via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 2 Feb 2021 18:49:54 +0000
Well, everything works fine when running as root. I am just being encouraged to stop doing that 🙂
Pete.
Sent: Tuesday, February 2, 2021 1:48 PM
To: Siddons, David <[email protected]>
On 2/2/21 10:09 AM, Siddons, David wrote:
> Hi Michael,
>    Setting 0666 doesn't help.
Maybe your kernel doesn't have /dev/mem enabled either?
> $ grep DEVMEM /boot/config-5.9.0-0.bpo.5-amd64
> CONFIG_DEVMEM=y
> CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
> CONFIG_STRICT_DEVMEM=y
> CONFIG_IO_STRICT_DEVMEM=y
> THanks for the link. I missed that before. It looks like the right way to go. I'll dig into it.
> Pete.
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Tuesday, February 2, 2021 12:13 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS Tech-Talk <[email protected]>
> *Subject:* Re: setcap and nosuid
> On 2/2/21 8:57 AM, Siddons, David wrote:
>> Hi David,
>> Yes, I saw that. Changing it doesn't seem to help:
>> sudo chmod g+w /dev/mem
>> ls -l /dev/mem
>> crw-rw---- 1 root kmem 1, 1 Feb  1 21:05 /dev/mem
>> ./regrw R 1   ( a program which maps the FPGA registers to userspace)
>> Reading Register 1
>> Can't open /dev/mem
> Have you tried chmod 0666 to make sure this is really a permission problem?
> The "Can't open" could also print 'errno'.
> Also, I feel obligated to repeat myself in recommending against using
> /dev/mem in any kind of long term solution.  There are safer ways
> to grant access to specific MMIO ranges.
> https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php>
Re: setcap and nosuid Michael Davidsaver via Tech-talk
Re: setcap and nosuid Siddons, David via Tech-talk
Prev: Re: setcap and nosuid Michael Davidsaver via Tech-talk
Next: Re: setcap and nosuid Michael Davidsaver via Tech-talk
