1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL]
From: "Akeroyd, Freddie \(STFC, RAL, ISIS\) via Tech-talk" <[email protected]>
To: "CORNALL, Terry" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 3 Feb 2021 09:47:51 +0000
I’m not familiar with this particular device setup, but in general errors like this can mean that the system was able to find the original file requested but not able to load some of its dependencies. This can be because the dependency is missing/inaccessible on the system, but also because an older/incompatible version of the requested dependency is already loaded by the IOC. A good starting point might be to run a program like  dependency walker http://www.dependencywalker.com/ on gbif64.dll and see if it detects a missing Visual Studio runtime library that you just need to install. If it doesn’t find anything missing, try starting the dependency walker program from the same command window you would run the IOC from but after you have run dllPath.bat – that way it should then be using the same search path the IOC would later be using and it might indicate if you have any DLL incompatibilities.
Freddie
From: Tech-talk <[email protected]> On Behalf Of CORNALL, Terry via Tech-talk
Sent: 03 February 2021 06:44
To: [email protected]
Subject: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL]
Hi All.
I’m running the perkinElmerIOC from the Windows 10 ADPerkinElmer areaDetector-3-8  binary distribution and I get the error:
PerkinElmer::initializeDetector, error=39 calling Acquisition_GbIF_Init(&hAcqDesc_=000001E40F1ACB40, nChannelNr=0, bEnableIRQ_=1, uiRows=1024, uiColumns=1024,bSelfInit=1, bInitAlways=0, IDType_=1, IDValue_=000001E40F1B5FC0)
Can anyone shed light on this?
I have found that error=39 means ‘Can’t load driver’ but as far as I can tell the gbif64.dll is in the right place (assuming that is the driver in question)  so I don’t know how to proceed in solving this issue.
Terry
OFFICIAL
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL] CORNALL, Terry via Tech-talk
Prev: Base 3.16.1.0 Mogamad Amien Crombie via Tech-talk
Next: Re: Base 3.16.1.0 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL] CORNALL, Terry via Tech-talk
Next: Re: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL] Mark Rivers via Tech-talk
