1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: How To Compile EPICS7 at RTEMS5.1
From: Joel Sherrill via Tech-talk <[email protected]>
To: 程司农 <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Fri, 5 Feb 2021 08:26:14 -0600
On Fri, Feb 5, 2021 at 7:54 AM 程司农 via Tech-talk <[email protected]> wrote:
Hello EPICS/RTEMS users,
I want to complie RTEMS at CentOS7, and get started EPICS with RTEMS, and my target board is mvme5500.So, I choose RTEMS5.1 and EPICS7 . I find some imformation in the https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en. I change the file configure/os/CONFIG_SITE.Common.RTEMS, then make RTEMS_BSP=mvme5500, there will be many .h header files missing. After adding a part, the rtems/bsd/modules.h file is now missing.
There is my env:
HOST: centOS7, Target board: mvme5500, RTEMS version: 5.1, EPICS version: 7.0(download from https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0 )
The build is stopping with following error:
[chengsn@localhost epicsBaseOwnPlayground-7.0]$ make RTEMS_BSP=mvme5500
make -C ./configure install
make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.linux-x86_64'
make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../.. \
    T_A=RTEMS-qoriq_e500 install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.RTEMS-qoriq_e500'
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.RTEMS-qoriq_e500'
make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure'
make -C ./src install
make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src'
make -C ./tools install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/convertRelease.pl
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/depclean.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
Installing generated html ../../../html/./EPICS/Getopts.html
mkdir ../../../html/./EPICS
Installing generated html ../../../html/./EPICS/Path.html
Installing generated html ../../../html/./EPICS/Readfile.html
Installing generated html ../../../html/./fullPathName.html
Installing generated html ../../../html/./munch.html
Installing generated html ../../../html/./podToHtml.html
Installing generated html ../../../html/./podRemove.html
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.linux-x86_64'
make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.RTEMS-qoriq_e500'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.RTEMS-qoriq_e500'
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools'
make -C template/base install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/Makefile
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.linux-x86_64'
make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.RTEMS-qoriq_e500'
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.RTEMS-qoriq_e500'
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base'
make -C template/ext install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseExt.pl
Installing ../../../../templates/makeBaseExt/top/Makefile
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/README
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.linux-x86_64'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.RTEMS-qoriq_e500'
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.RTEMS-qoriq_e500'
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext'
make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src'
make -C ./test install
make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test'
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.linux-x86_64'
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.linux-x86_64'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.RTEMS-qoriq_e500'
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.RTEMS-qoriq_e500'
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools'
make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test'
make -C ./modules install
make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules'
make -C ./libcom install
make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure'
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.linux-x86_64'
Installing CFG file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg/CONFIG_LIBCOM_MODULE
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg
Installing CFG file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg/CONFIG_LIBCOM_VERSION
perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.linux-x86_64'
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.RTEMS-qoriq_e500'
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.RTEMS-qoriq_e500'
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure'
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src'
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.linux-x86_64'
Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl
perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/convertRelease.pl -T ../.. /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/libcomModuleDirs.pm
perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl  -t linux-x86_64 \
-c gcc -s Linux /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure
Generating envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include           -MM -MF envData.d  envData.c
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/valgrind/valgrind.h
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/valgrind
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComVersion.h
Installing generated generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComVersionNum.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/asLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/asTrapWrite.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/bucketLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/postfix.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/cvtFast.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAlgorithm.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExcept.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/resourceLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsDLList.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsSLList.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsMinMax.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsFreeList.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSingleton.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsGuard.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/dbmf.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/ellLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/envDefs.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsPrint.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errMdef.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errSymTbl.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errlog.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/fdManager.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/fdmgr.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/flex.skel.static
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/freeList.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/gpHash.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/iocsh.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/initHooks.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/registry.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComRegister.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/iocLog.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/logClient.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/macLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/alarm.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/alarmString.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/adjustment.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/cantProceed.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/dbDefs.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsConvert.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExit.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdlib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsString.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTypes.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/shareLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExport.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/unixFileName.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/locationException.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/ipAddrToAsciiAsynchronous.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compilerDependencies.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsUnitTest.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/testMain.h
Installing generated generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsVersion.h
Installing compiler dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc/compilerSpecific.h
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osiFileName.h
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiSock.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdSock.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsInterrupt.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdInterrupt.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMutex.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdMutex.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSpin.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsEvent.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdEvent.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMath.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdMessageQueue.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdStrtod.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAssert.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsFindSymbol.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiPoolStatus.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdPoolStatus.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdThread.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsThread.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTime.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsGeneralTime.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdTime.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/generalTimeSup.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiClockTime.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSignal.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiProcess.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osiUnistd.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiWireFormat.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdWireFormat.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdWireConfig.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAtomic.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAtomicDefault.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsAtomicOSD.h
Installing compiler dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc/epicsAtomicCD.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsEndian.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsReadline.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMessageQueue.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdio.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdioRedirect.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTempFile.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsGetopt.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStackTrace.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLib.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLibVME.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLibVMEImpl.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdVME.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMMIO.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMMIODef.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsThreadPool.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRingPointer.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRingBytes.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/taskwd.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTimer.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_alloc.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_common.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_gen.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_parse.h
Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope
/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope -bparse -l -d ../../src/flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c parse.c
/usr/bin/g++ -o e_flex  -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         epicsTempFile.o ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/e_flex
/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/e_flex -S/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/flex.skel.static -8 -I -oasLib_lex.c ../../src/as/asLib_lex.l
/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope -basLib  ../../src/as/asLib.y
mv asLib.tab.c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF asLib.d  asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF parse.d  parse.c
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.linux-x86_64'
Installing PERL_MODULES file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/perl/EPICS/macLib.pm
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c envData.c
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
/usr/bin/g++ -o libCom.so.3.17.2 -shared -fPIC -Wl,-hlibCom.so.3.17.2 -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.so.3.17.2
ln -s libCom.so.3.17.2 /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.so
Installing library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.a
/usr/bin/g++ -o iocLogServer  -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/S99logServer
Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/iocLogServer
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.RTEMS-qoriq_e500'
perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl  -t RTEMS-qoriq_e500 \
-c gcc -s RTEMS /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc  -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF envData.d  envData.c
/bin/mv asLib.tab.c asLib.c
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc  -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF asLib.d  asLib.c
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.RTEMS-qoriq_e500'
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osiFileName.h
mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdSock.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdInterrupt.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdMutex.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdEvent.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMath.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdMessageQueue.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdStrtod.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdPoolStatus.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdThread.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdTime.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osiUnistd.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdWireFormat.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdWireConfig.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsAtomicOSD.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsGetopt.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdVME.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMMIO.h
Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMMIODef.h
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c asLib.c
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c envData.c
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-ar rc   libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-ranlib libCom.a
Installing library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/RTEMS-qoriq_e500/libCom.a
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src'
make -C ./RTEMS install
make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS'
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.linux-x86_64'
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRtemsInitHooks.h
Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMemFs.h
Installing script /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/epicsMakeMemFs.pl
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.linux-x86_64'
make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.RTEMS-qoriq_e500'
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I. -I.. -I../posix -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c ../posix/rtems_init.c
../posix/rtems_init.c: In function 'initialize_local_filesystem':
../posix/rtems_init.c:193:17: warning: unused variable '_FlashSize' [-Wunused-variable]
     extern char _FlashSize[]  __attribute__((weak));
../posix/rtems_init.c:192:17: warning: unused variable '_FlashBase' [-Wunused-variable]
     extern char _FlashBase[] __attribute__((weak));
../posix/rtems_init.c:191:17: warning: unused variable '_DownloadLocation' [-Wunused-variable]
     extern char _DownloadLocation[] __attribute__((weak));
../posix/rtems_init.c: In function 'default_network_dhcpcd':
../posix/rtems_init.c:686:14: warning: implicit declaration of function 'rtems_dhcpcd_start'; did you mean 'rtems_telnetd_start'? [-Wimplicit-function-declaration]
         sc = rtems_dhcpcd_start(NULL);
              rtems_telnetd_start
This is a method in rtems-libbsd (new TCP/IP stack) and not provided in the legacy stack in cpukit/libnetworking.
The mvme5000/beatnik currently does not support the new TCP/IP stack.
There would have to be different network configuration and initialization code based on the network stack used.
Perhaps Heinz can offer more.
--joel
RTEMS
../posix/rtems_init.c: In function 'POSIX_Init':
../posix/rtems_init.c:699:25: warning: unused variable 'cp' [-Wunused-variable]
     char               *cp;
/home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I. -I.. -I../posix -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c ../posix/rtems_config.c
In file included from /home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/include/machine/rtems-bsd-config.h:230:0,
                 from ../posix/rtems_config.c:92:
/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/include/bsp/nexus-devices.h:40:10: fatal error: rtems/bsd/modules.h: No such file or directory
 #include <rtems/bsd/modules.h>
compilation terminated.
make[4]: *** [rtems_config.o] Error 1
make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.RTEMS-qoriq_e500'
make[3]: *** [install.RTEMS-qoriq_e500] Error 2
make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS'
make[2]: *** [RTEMS.install] Error 2
make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom'
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules'
make: *** [modules.install] Error 2
Did I do something wrong?
Best regards,
chengsn
How To Compile EPICS7 at RTEMS5.1 程司农 via Tech-talk
Prev: How To Compile EPICS7 at RTEMS5.1 程司农 via Tech-talk
Next: Re: How To Compile EPICS7 at RTEMS5.1 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
