1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Question about control curves displayed in databrowser widget for CSS OPI boy.
To: Manoussakis, Adamandios <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 6 Feb 2021 08:50:20 +0800
Dear Adam and all,
Thanks for your reply. It is a good idea.
Sorry, I didn't make myself clear. Therefore, I modify the title of my problem.
I intend to control one or more of the curves displayed in databrowser widget visible or invisible that loaded .plt file (databrowser file) when CSS OPI boy is running by clicking the checkbox or combo box widget that I set in the OPI boy. Maybe I should set rules for databrowser widget to connect to checkbox or combo box widget, but I have no idea how to implement that. There is no example for this case in CSS.
Any help will be appreciated and thank you very much.
Zhefu
Date: 2021-02-06 05:57
Subject: RE: Question about databrowser of CSS
I think this may be something similar I ran into with the databrowser but please correct me if I am wrong.  The databrowser is not able to display arrays, it only seems to grab scalar values from a record even if it’s an array of values it will only display index[0].  Therefore your data when you “Add PV” to the databrowser it will look quite strange if you were expecting your array to show up.
Adam
From: Tech-talk <[email protected]> On Behalf Of lzf neu via Tech-talk
Sent: Thursday, February 4, 2021 4:46 PM
To: [email protected]
Subject: Question about databrowser of CSS
Dear all,
I have two questions about databrowser to consult you,
1) I intend to display single or multiple archive data curves in databrowser of CSS by clicking checkbox for the corresponding curve name.
2) To display single archive data curve by clicking combo box for the corresponding curve name.
 I have no idea how to implement that. Could you please show me an example or method in detail. Any help will be appreciated and thank you very much in advance.
Question about databrowser of CSS lzf neu via Tech-talk
RE: Question about databrowser of CSS Manoussakis, Adamandios via Tech-talk
Prev: Re: Dynamic user limits in softMotor Mooney, Tim M. via Tech-talk
Next: Re: Dynamic user limits in softMotor Laurenz Rettig via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Question about databrowser of CSS Manoussakis, Adamandios via Tech-talk
Next: Re: Question about databrowser of CSS Kasemir, Kay via Tech-talk
