Subject: pmacAsynCoord in-position vs .MOVN
From: "Hidas, Dean via Tech-talk" <[email protected]>
Date: Tue, 16 Feb 2021 16:32:12 +0000
Dear EPICS Experts,
I'm using pmacAsynCoord with a pmac turbo2 brick controller.  What I notice is that occasionally the pmac reports that a move is finished, that the coordinate system is not motion, but the .MOVN field of the motor record stays high despite reaching the desired position and not actually being in motion.  At this point the pmac reports in position, but the motor record does not seem to have any additional control effect (nor should it I believe), ie the .MOVN field stays high but there is no further motion.  Are there any motor record fields or other parameters you might advise having a look at that could have an effect on this?
Thank you in advance for your help,
-Dean Hidas
Dean Andrew Hidas, Ph.D.
Physicist
Brookhaven National Laboratory
Upton, NY 11973, U.S.A.
Phone: +1 631 344 3568
https://hidas.org
Re: pmacAsynCoord in-position vs .MOVN Kevin Peterson via Tech-talk
Re: pmacAsynCoord in-position vs .MOVN J. Lewis Muir via Tech-talk
Prev: Re: Yet another calc record / CPP link problem Michael Davidsaver via Tech-talk
Next: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Prev: Re: Detect PV connect and disconnect events in CSS Kasemir, Kay via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN Kevin Peterson via Tech-talk
