1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: How to capture messages generated by PyEpics?
To: "'Li, Ji'" <[email protected]>
Date: Fri, 19 Feb 2021 01:11:00 +0000
Ø   When I get/set from PyEpics (tried both PV module and CA module), the program was able to successfully get the up-to-date value of the PV and set new value to it,
Ø  > but no messages showed up. Doesn't PyEpics communicate using CA protocol messages? Are there specific filter/configuration to be done in Wireshark to show these messages?
There is no difference in the CA network messages using caget and PyEpics.    They both use the same libca.so library from EPICS base.
You must have something configured wrong in Wireshark or something.
From: Tech-talk <[email protected]> On Behalf Of Li, Ji via Tech-talk
Sent: Thursday, February 18, 2021 4:52 PM
To: [email protected]
Subject: How to capture messages generated by PyEpics?
I'm trying to capture CA messages targeting a specific PV on the IOC server with Wireshark (v1.12.1) and Michael Davidsaver's cashark plugin (ca.pv or ip.addr as the filter). Wireshark was able to capture messages generated by caget/caput commands ran from bash. When I get/set from PyEpics (tried both PV module and CA module), the program was able to successfully get the up-to-date value of the PV and set new value to it, but no messages showed up. Doesn't PyEpics communicate using CA protocol messages? Are there specific filter/configuration to be done in Wireshark to show these messages? Thanks.
-Ji Li
回复: How to capture messages generated by PyEpics? Li, Ji via Tech-talk
Prev: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Next: 回复: How to capture messages generated by PyEpics? Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: How to capture messages generated by PyEpics? Li, Ji via Tech-talk
