Subject: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame
From: "Ivashkevych, Oksana via Tech-talk" <[email protected]>
To: Tech-talk <[email protected]>
Date: Tue, 23 Feb 2021 16:05:40 +0000
Hello,
I am trying to configure hdf5 plugin to save N images with 4 ROI data (start, size), and 4 Stats, connected to ROIs ( total , maxValue).
I have created Attributes.xml file  following example from ADSimDetector. type="EPICS_PV" works, however type="PARAM" does not for parameters from areaDetector/ADCore/ADApp/pluginSrc/, but does work for params from areaDetector/ADCore/ADApp/ADSrc/.
It looks like with "EPICS_PV" type statistics data come from the previous frame.
I was wondering if there is something I am missing, or there are other ways to get the correct statistics into the hdf5 file. I have tried using Stats, ROIStats, and ROI plugins.
The green attributes are correctly saved, others show NaN in hdf5 file.
I have ADCore 3.6.0; ADPilatus 2.6.0
Thank you
Attributes.xml:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="DriverFileName"  type="PARAM"    source="FULL_FILE_NAME"                       datatype="STRING"     description="Driver file name"/>
    <Attribute name="ROI0Size"      type="PARAM"    source="DIM0_SIZE"              datatype="INT"     description="X size ROI 0"/>
    <Attribute name="ROI0Mean"      type="PARAM"    source="MEAN_VALUE"              datatype="DOUBLE"     description="Mean value ROI 0"/>
    <Attribute name="ROI1Mean"      type="PARAM"    source="MEAN_VALUE" addr="1"     datatype="DOUBLE"     description="Mean value ROI 0"/>
    <Attribute name="_ROI0Total"     type="PARAM"    source="ROISTAT_TOTAL"                   datatype="DOUBLE"     description="Total counts ROI 0"/>
    <Attribute name="_ROI1Total"     type="PARAM"    source="ROISTAT_TOTAL"      addr="1"     datatype="DOUBLE"     description="Total counts ROI 1"/>
    <Attribute name="MaxSizeX"            type="PARAM"    source="MAX_SIZE_X"                   datatype="INT"        description="Detector X size"/>
    <Attribute name="MaxSizeY"            type="PARAM"    source="MAX_SIZE_Y"                   datatype="INT"        description="Detector Y size"/>
    <Attribute name="CameraModel"         type="PARAM"    source="MODEL"                        datatype="STRING"     description="Camera model"/>
    <Attribute name="AttributesFileParam"  type="PARAM"   source="ND_ATTRIBUTES_FILE"            datatype="STRING"     description="Attributes file param"/>
    <Attribute name="CameraManufacturer"  type="PARAM"    source="MANUFACTURER"                 datatype="STRING"     description="Camera manufacturer"/>
</Attributes>
Re: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
Prev: Re: Matlab 2020b crashes with labCA 3.7.2 Till Straumann via Tech-talk
Next: Re: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
