Subject: Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode
From: "Usmani, Imran Ali via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Mar 2021 04:06:28 +0000
Thanks Kay, this works for me.
One more question, is there a way to open this new resource window in full screen mode?
Imran
Sent: Monday, March 15, 2021 6:09 PM
To: [email protected] <[email protected]>; Usmani, Imran Ali <[email protected]>
Add 'target=window' to the resource:
       phoebus.sh -resource file:/full/path/to/file?target=window
From: Tech-talk <[email protected]> on behalf of Usmani, Imran Ali via Tech-talk <[email protected]>
Sent: Monday, March 15, 2021 3:31 PM
Subject: [EXTERNAL] Open additional resources as a separate window(not tab) in CSS-Phoebus server mode
Hi everyone,
I am looking for a cmd line option to open additional resources as a separate window(not as a separate tab in the main window) in server mode for CSS-Phoebus.
I can start CSS-phoebus with:
# /bin/java  -jar  phoebus/target/product-4.6.3.jar -server 4918
Now I can open file xyz.plt with databrowser app on same css-phoebus server using:
# /bin/java  -jar  phoebus/target/product-4.6.3.jar -server 4918 -resource xyz.plt
This opens a databrowser tab in the main css-phoebus UI window.
I want a command(from bash) to open this resource as a separate window not as a separate tab in main UI window.
It should be on the same css-phoebus server, not on a new phoebus instance.
The reason I need to open this as a separate window is because
I want a create bash script which opens multiple resources on a single css-phoebus server in different linux work spaces.
PS: I can open each resource as a separate css-phoebus instance(in non-server mode), I don't want that because it will be slow and memory intensive.
Imran
Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Kasemir, Kay via Tech-talk
Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode J. Lewis Muir via Tech-talk
Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Usmani, Imran Ali via Tech-talk
Prev: Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Kasemir, Kay via Tech-talk
Next: Re: Existing device support Abdalla Ahmad via Tech-talk
Next: Re: Open additional resources as a separate window(not tab) in CSS-Phoebus server mode Kasemir, Kay via Tech-talk
