There is one other possible solution.
Enable Scale&Offset. Set the scale=1.0 and offset=N where N is chosen to be a bit larger than your estimate of the largest background value. That increases the values so they won't be negative, while not clipping values. It does make it possible that very large values could overflow if they are close to 65535.
-----Original Message-----
Sent: Tuesday, March 16, 2021 5:36 PM
To: 'Laurenz Rettig' <[email protected]>
Cc: [email protected]
Subject: RE: NDPluginProcess Background subtraction UInt wrap around
> I'm having some trouble with the background subtraction in the NDPluginProcess and UInt16 data type.
> Whenever the values would turn negative due to the background subtraction, the UInt16 wraps around and produces values close to 65536.
> What is the best way to avoid this this?
That depends on what you want to get from the output.
If you want to preserve the negative values then you could set the output data type to Int32. That will make the output arrays larger, but it will preserve UInt16 values up to 65535 as well as handle negative numbers.
If you are OK with clipping negative numbers to 0 then you could do what Hugo suggested and clip the low value to 0. Then the output arrays can be left as UInt16 data type.
From: Tech-talk <[email protected]> On Behalf Of Laurenz Rettig via Tech-talk
Sent: Tuesday, March 16, 2021 5:19 PM
To: [email protected]
Subject: NDPluginProcess Background subtraction UInt wrap around
I'm having some trouble with the background subtraction in the NDPluginProcess and UInt16 data type. Whenever the values would turn negative due to the background subtraction, the UInt16 wraps around and produces values close to 65536. What is the best way to avoid this this?
Thanks, Laurenz
Dr. Laurenz Rettig
Fritz Haber Institute of the Max Planck Society Department of Physical Chemistry Dynamics of Correlated Materials Faradayweg 4-6
14195 Berlin, Germany
phone: +49-(0)30-8413 5225
email: [email protected]
- NDPluginProcess Background subtraction UInt wrap around Laurenz Rettig via Tech-talk
- RE: NDPluginProcess Background subtraction UInt wrap around Mark Rivers via Tech-talk
CA archeology request Michael Davidsaver via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
