Subject: MRF kernel module, failed to map BARS
From: GAGET Alexis via Tech-talk <[email protected]>
Date: Tue, 23 Mar 2021 15:34:33 +0000
Dear All,
Here at saclay we are using MRF timing system with MTCA.4 in R2 NAT crate.
I’m using the COMex-E3 and a MCH-PHYS80. The IOC using the mrfioc2 driver is running on the Comex and the mrf kernel module is loaded on it. I have forked from ESS version of mrfioc2, and the kernel module I built seems the same.
My kernel version is : 3.10.0-1160.15.2.el7.x86_64 on a CenTOS Linux 7.9.2009
It works globally very well, but I have a reproducible issue:
When I reboot the whole R2 crate and when I load the MRF kernel module I have the following message :
 [  347.344081] mrf: module verification failed: signature and/or required key missing - tainting kernel
[  347.345504] mrf-pci 0000:04:00.0: Attaching MRF device w/o PLX bridge (00007011)
[  347.345581] mrf-pci 0000:04:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0]
[  347.345646] mrf-pci 0000:04:00.0: Failed to map BARS! 0 0
[  347.345918] mrf-pci 0000:06:00.0: Attaching MRF device w/o PLX bridge (00007011)
[  347.345989] mrf-pci 0000:06:00.0: can't ioremap BAR 0: [??? 0x00000000 flags 0x0]
[  347.346053] mrf-pci 0000:06:00.0: Failed to map BARS! 0 0
Consequence, my Comex can’t find some of my EVR or EVM (some are found..).
To make it work I just have to reboot the Comex and after that it’s working. Meaning after a shutdown I have to reboot it twice…
Does anyone have this kind of trouble ? Knows how to solve it ? or even understand this message ?
Thanks for your consideration
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
Bâtiment 472 – pièce 105
[email protected]
01 69 08 95 17
Re: MRF kernel module, failed to map BARS Lucas Russo via Tech-talk
Re: MRF kernel module, failed to map BARS Michael Davidsaver via Tech-talk
Prev: Phoebus: archive-engine export and enable issues Kuldeep Joshi via Tech-talk
Next: Re: MRF kernel module, failed to map BARS Lucas Russo via Tech-talk
