Subject: Re: Area Detector and Flea2 camera problem
From: Jeong Han Lee via Tech-talk <[email protected]>
To: Miroslaw Dach <[email protected]>
Date: Thu, 25 Mar 2021 18:44:41 -0700
Hi Mirek,
My suspicion remains in the following options:
> # Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
> epicsEnvSet("CAMERA_ID", "9211601")
> pointGreyConfig("PG1", 18402100, 0x1, 0)
The second arg of pointGreyConfig is Camera ID, The first option is
"epics variable", but the second is you use the hardcode value.
If it is not your case, it is better to check the connection through
the vendor software whether you can connect or not.
Best,
Han
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.651 pointGrey:pointGrey:  camera connection failed (3)
> Number of cameras detected: 0
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
> Supported properties
> ./start_epics: line 1: 78175 Segmentation fault      (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
> kernel reports the following problem:
> 692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
> [692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
> Does anybody have an idea what might be wrong?
> Best Regards
> Mirek
Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Prev: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Next: Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
