Subject: Re: Area Detector and Flea2 camera problem
From: Miroslaw Dach via Tech-talk <[email protected]>
Date: Mon, 29 Mar 2021 14:57:22 -0700
Hi Mark and Han,
Thank you very much for your expertise and suggestions.
>This means that the vendor SDK is unable to find any Point Grey/FLIR cameras.
I will just give a last try. I will read the serial number and set it explicitly in EPICS db.
>The Flea2 is a Firewire camera.  In principle that is supported by the FlyCap2 SDK that ADPointGrey uses.  However, I am not sure if anyone has actually used a Point Grey Firewire camera with ADPointGrey on Linux, and almost certainly not on a Ubuntu 20.
Does it mean that the Flea2 would work with area-detector under Windows?
>Is replacing the camera an option?  New GigE or USB-3.0 cameras with much better performance than the Flea2 are less than $500.
Well, we just have this camera so we wanted to make use of it even if it is not so new.
Best Regards
Mirek
On Thu, Mar 25, 2021 at 7:20 PM Mark Rivers <[email protected]> wrote:
Hi Mirek,
> Number of cameras detected: 0
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
Firewire cameras are not supported by the new FLIR Spinnaker SDK, so upgrading to that is not an option.
From: Tech-talk <[email protected]> on behalf of Miroslaw Dach via Tech-talk <[email protected]>
Sent: Thursday, March 25, 2021 8:09 PM
To: [email protected]
Subject: Area Detector and Flea2 camera problem
Hello,
I am using the latest Area Detector R3-10 on Ubuntu 20.04 focal (x86-64).
Unfortunately the Flea2 camera which is connected to the computer is not detected:
Startup script:
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/../..")
epicsEnvSet("SUPPORT","/home/beamline/EPICS/synApps/support")
epicsEnvSet("ASYN","/home/beamline/EPICS/synApps/support/asyn-R4-41")
epicsEnvSet("AREA_DETECTOR","/home/beamline/EPICS/synApps/support/areaDetector-R3-10")
epicsEnvSet("ADSUPPORT","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADSupport")
epicsEnvSet("ADCORE","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADCore")
epicsEnvSet("AUTOSAVE","/home/beamline/EPICS/synApps/support/autosave-R5-10-2")
epicsEnvSet("BUSY","/home/beamline/EPICS/synApps/support/busy-R1-7-3")
epicsEnvSet("CALC","/home/beamline/EPICS/synApps/support/calc-R3-7-4")
epicsEnvSet("SNCSEQ","/home/beamline/EPICS/synApps/support/seq-2-2-8")
epicsEnvSet("SSCAN","/home/beamline/EPICS/synApps/support/sscan-R2-11-4")
epicsEnvSet("DEVIOCSTATS","/home/beamline/EPICS/synApps/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/home/beamline/EPICS/base-7.0.5")
errlogInit(20000)
dbLoadDatabase("/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/dbd/pointGreyApp.dbd")
# Prefix for all records
epicsEnvSet("PREFIX", "13PG1:")
# Use this line for the first Point Grey camera in the system
epicsEnvSet("CAMERA_ID", "0")
# Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
epicsEnvSet("CAMERA_ID", "9211601")
pointGreyConfig("PG1", 18402100, 0x1, 0)
2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.651 pointGrey:pointGrey:  camera connection failed (3)
2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
Supported properties
./start_epics: line 1: 78175 Segmentation fault      (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
kernel reports the following problem:
692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
[692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
Does anybody have an idea what might be wrong?
Best Regards
Mirek
RE: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Prev: Question about ACROMAG IP-408 Wang, SuYin Grass via Tech-talk
Next: RE: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Prev: Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
