Hi Mark,
A long ago, I set up the GigE, not Firewire, PointGrey Camera,
Blackfly BLFY-PGE-23S6C (Firmware 1.66.3.0), on Debian 9 with Ubuntu
Linux SDK, but only the shared lib - libflycapture.so.2.9.3.43, and it
worked with ADPointGrey module with the version 2.7.0.
HTH,
Han
On Thu, Mar 25, 2021 at 7:21 PM Mark Rivers via Tech-talk
<[email protected]> wrote:
> Hi Mirek,
> > Number of cameras detected: 0
> > 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
> This means that the vendor SDK is unable to find any Point Grey/FLIR cameras.
> The Flea2 is a Firewire camera. In principle that is supported by the FlyCap2 SDK that ADPointGrey uses. However, I am not sure if anyone has actually used a Point Grey Firewire camera with ADPointGrey on Linux, and almost certainly not on a Ubuntu 20.
> Firewire cameras are not supported by the new FLIR Spinnaker SDK, so upgrading to that is not an option.
> Is replacing the camera an option? New GigE or USB-3.0 cameras with much better performance than the Flea2 are less than $500.
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Miroslaw Dach via Tech-talk <[email protected]>
> Sent: Thursday, March 25, 2021 8:09 PM
> To: [email protected]
> Subject: Area Detector and Flea2 camera problem
> Hello,
> I am using the latest Area Detector R3-10 on Ubuntu 20.04 focal (x86-64).
> Unfortunately the Flea2 camera which is connected to the computer is not detected:
> Startup script:
> epicsEnvSet("IOC","iocPointGrey")
> epicsEnvSet("TOP","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC")
> epicsEnvSet("ADPOINTGREY","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/../..")
> epicsEnvSet("SUPPORT","/home/beamline/EPICS/synApps/support")
> epicsEnvSet("ASYN","/home/beamline/EPICS/synApps/support/asyn-R4-41")
> epicsEnvSet("AREA_DETECTOR","/home/beamline/EPICS/synApps/support/areaDetector-R3-10")
> epicsEnvSet("ADSUPPORT","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADSupport")
> epicsEnvSet("ADCORE","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADCore")
> epicsEnvSet("AUTOSAVE","/home/beamline/EPICS/synApps/support/autosave-R5-10-2")
> epicsEnvSet("BUSY","/home/beamline/EPICS/synApps/support/busy-R1-7-3")
> epicsEnvSet("CALC","/home/beamline/EPICS/synApps/support/calc-R3-7-4")
> epicsEnvSet("SNCSEQ","/home/beamline/EPICS/synApps/support/seq-2-2-8")
> epicsEnvSet("SSCAN","/home/beamline/EPICS/synApps/support/sscan-R2-11-4")
> epicsEnvSet("DEVIOCSTATS","/home/beamline/EPICS/synApps/support/iocStats-3-1-16")
> epicsEnvSet("EPICS_BASE","/home/beamline/EPICS/base-7.0.5")
> errlogInit(20000)
> dbLoadDatabase("/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/dbd/pointGreyApp.dbd")
> # Prefix for all records
> epicsEnvSet("PREFIX", "13PG1:")
> # Use this line for the first Point Grey camera in the system
> epicsEnvSet("CAMERA_ID", "0")
> # Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
> epicsEnvSet("CAMERA_ID", "9211601")
> pointGreyConfig("PG1", 18402100, 0x1, 0)
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.651 pointGrey:pointGrey: camera connection failed (3)
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
> Supported properties
> ./start_epics: line 1: 78175 Segmentation fault (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
> kernel reports the following problem:
> 692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
> [692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
> Does anybody have an idea what might be wrong?
> Best Regards
> Mirek
- Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
- Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
RE: Question about ACROMAG IP-408 Mark Rivers via Tech-talk
Re: Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
<2021>
2025
2026
Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
[CS-Studio] is there a way to always open a view in "OPI editor" when double-clicking on it ? Victor Nadot via Tech-talk
<2021>
2025
2026
