Subject: How to use asyGenericPointerSyncIO interface?
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 20 Apr 2021 10:11:07 +0000
Hi
We want to write a driver for a device we have in which its command interface consists of bytes in a specific order (like C structs), for example first byte is command type, 2nd byte is address and then followed by 4 bytes as the data; 6 bytes in total. Is asyGenericPointerSyncIO the correct choice? I could not see anywhere in the sync IO interfaces where I pass the struct size (Like in the write/read system calls). How does the write/read operations work with these interfaces and how do they detect how many bytes to write? Do I need to use the void pointers inside the asynUser structure?
Thanks!
Abdalla
Re: How to use asyGenericPointerSyncIO interface? Mark Rivers via Tech-talk
Prev: Re: pv Access setup Дмитрий Прощенко via Tech-talk
Next: Re: How to use asyGenericPointerSyncIO interface? Mark Rivers via Tech-talk
Prev: Re: display builder questions Kasemir, Kay via Tech-talk
