Subject: Re: [EXTERNAL] What is the best (and simple) way to implement security in a Phoebus solution?
From: Oscar Ibañez via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 21 Apr 2021 21:43:34 +0200
Hi Mr. Kay,
Thank you very much for you answer.
This is the kind of orientation that I needed. Anyway, I have answered another user's message requesting more information about my problem. However, and taking into account what you have told me, it seems that the avaliable solutions are limited.
Best,
Óscar
El 21/04/2021 a las 14:19, Kasemir, Kay escribió:
Is there any recomendable solution to implement username authentication
in Phoebus? I mean, some kind of solution to save critical information
(password hash?) that, then, it will be used to authenticate an user.
Phoebus itself doesn't perform authentication. It depends on the full power of the operating system and simply accepts the current user as an authenticated user.
We do support authorization so you can for example enable/disable certain features in your code based on the current user, see online help https://control-system-studio.readthedocs.io/en/latest/authorization.html
There is also a SecureStore class based on the standard Java KeyStore that can be used to store name/value pairs, but it only offers weak protection when you use it with the default, code-generated password, see https://github.com/ControlSystemStudio/phoebus/blob/master/core/security/src/main/java/org/phoebus/security/store/SecureStore.java
-Kay
What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Re: [EXTERNAL] What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Prev: Re: What is the best (and simple) way to implement security in a Phoebus solution? Oscar Ibañez via Tech-talk
Next: Re: [EXTERNAL] Re: What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Prev: Re: [EXTERNAL] What is the best (and simple) way to implement security in a Phoebus solution? Kasemir, Kay via Tech-talk
Next: Re: What is the best (and simple) way to implement security in a Phoebus solution? J. Lewis Muir via Tech-talk
