Subject: Re: pvdata structure not writing to other pvs
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Pierrick Hanlet <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 23 Apr 2021 21:31:41 +0000
Hi Pierrick,
Does the iocsh ‘dbpvar’ command tell you anything interesting/useful about the state of the pva link? You can give it a record name, or “*”, and an integer level for more and more detail about the link(s).
- Andrew
On Apr 23, 2021, at 4:10 PM, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
> Hi all,
> I'm running v7.0.3.1 on an SL7.8 machine.  I'm using structured data, with a sub-structure
> called Control.  I know that the structure/sub-structure is being properly set by testing it
> with a pvmonitor:
> pvmonitor -r Control P:S12OFP
> which yields:
> P:S12OFP structure
>     structure Control
>         time_t timeStamp <undefined>
>             long secondsPastEpoch 0
>             int nanoseconds 0
>             int userTag 0
>         short value 8
> I want this Control value to populate another record which has the form:
> record(longin,"PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs") {
>     field(DESC,"Trigger Control PVs from acnet device")
>     field(SCAN,"Passive")
>     field(INP,{pva:{pv:"P:S12OFP",
>             field:"Control.value",
>             proc:"CP"}})
>     field(FLNK,"PIP2IT-HPRF-SSR1-SSA2-00:OFP:SetPVs.PROC")
> However, this value doesn't change despite its input value changing.  Furthermore,
> if I attempt to change it's value with:
> caput PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs
> then get the error:
> Old : PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs 0
> CA.Client.Exception...............................................
>     Warning: "Channel write request failed"
>     Context: "op=1, channel=PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs, type=DBR_STRING, count=1, ctx="PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs""
>     Source File: ../oldChannelNotify.cpp line 160
> New : PIP2IT-HPRF-SSR1-SSA2-00:OFP:ControlPVs 0
>     Current Time: Fri Apr 23 2021 15:45:03.687389769
> Thank you,
> Pierrick
> Pierrick Hanlet
> Fermi National Accelerator
> Accelerator Front End Controls
> +1-630-840-5555 -- lab
> +1-312-687-4980 -- mobile
> "Whether you think you can or think you can't, you're right" -- Henry Ford
Complexity comes for free, simplicity you have to work for.
Re: pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
Prev: pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
Next: Re: pvdata structure not writing to other pvs Pierrick M Hanlet via Tech-talk
