Subject: Re: Areadetector ADVimba Frame error
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Date: Mon, 26 Apr 2021 12:44:49 +0000
Hi Mark
Thank you for your suggestion.
ADVimba version in R1-1 running on linux and I have configured net.core.rmem_max and net.core.rmem_default settings. But still, I get this error " ADVimba::processFrame error GetReceiveStatus returned 0 frameStatus=-1"
Thanks
Sandeep
Sent: 26 April 2021 17:07
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Cc: [email protected] <[email protected]>
Hi Sandeep,
What version of ADVimba are you using?
Are you running on Linux or Windows?
What percent of the frames are dropped?
If you are running on Linux have you followed the instructions about setting the Linux net.core.rmem_max and net.core.rmem_default settings here:
https://areadetector.github.io/master/ADGenICam/ADGenICam.html#linux-usb-and-gige-system-settings
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Sent: Monday, April 26, 2021 4:28 AM
To: [email protected]
Subject: Areadetector ADVimba Frame error
Hi
I am running ADvimba driver for AVT Manta G125 camera model. I can see camera streaming and Image counter running  but at the same time, On the EPICS console I get the error messages quite often " ADVimba::processFrame error GetReceiveStatus returned 0 frameStatus=-1"
Any suggestions would be highly appreciated.
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Re: Areadetector ADVimba Frame error Ha, Kiman via Tech-talk
RE: Areadetector ADVimba Frame error Mark Rivers via Tech-talk
Areadetector ADVimba Frame error Sandeep Kumar Malu - STFC UKRI via Tech-talk
Re: Areadetector ADVimba Frame error Mark Rivers via Tech-talk
Prev: Re: Areadetector ADVimba Frame error Mark Rivers via Tech-talk
Next: Re: Areadetector ADVimba Frame error Ha, Kiman via Tech-talk
