Hi Ryu,
I have not worked with linux-arm, so I may be off base.
Error messages like this:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
often mean that the version of gcc (which supplies GLBIC) is older than the version required by a library you are using.
Where did you get this file? /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a
That seems like an unusual location for the X11 library file.
From: Tech-talk <[email protected]> on behalf of Huyn Woo Ryu via Tech-talk <[email protected]>
Sent: Tuesday, April 27, 2021 4:51 AM
To: [email protected]
Subject: how to install alh on raspberry pi 4
Hi,I installed base-3.15.8 successfully on raspberry piBut when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2 I don't know how to fix it, could you give me some advice on it?Please, Help me! I consumed many time for this problem.Ryu
- Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
- how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
RE: RPM packages for EPICS Abdalla Ahmad via Tech-talk
Re: List all available PVs Kasemir, Kay via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
