Our machine, NSLS-II, has been in Shutdown mode since the end of March and it is going to start up soon.
We are doing system checkup, preparing for the machine startup. We just found some disconnected PVs on our CS-Studio screens this morning. I am scratching my head to find out which IOC hosts them. We used to use the simple approach "dbl >pv.list" as Kay mentioned. I did a grep, nothing found. Probably I or someone else forgot to put "dbl >pv.list" at the end of that IOC's st.cmd. We are in the process of using Michael's "RecSync" in our IOCs, most of them are 5-year-old or more older. Probably because I or someone else forgot to add the support module "reccaster" to that IOC, I did a search in CS-Studio Channel Viewer, nothing found again. Now I am totally dumb __
Cheers,
Yong
On 4/27/21, 11:30 AM, "Tech-talk on behalf of Stainer Tom via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
Thank you Kay and Michael for the help and advice. I had come across Channel Finder & recsync previously but I wasn't quite sure how it worked and what it did exactly (I was also unsure if it supported PVA, given the name).
Your responses have been very helpful.
I will look into the documentation and try it out.
Kind regards,
Tom
Hi:
> If I may continue with your analogy and the case of the web, then in this context there are web crawlers that exist for the sole purpose to index web sites and to see what is out there on the web (whether advertised or not).
> Similarly, I would like to know how one would go about making such a crawler for PVA, which could or could not be used in combination with a central registry.
Right, I assume in the long run most sites come up with some way to catalog their PVs.
One motivation: If a PV is online, you can use 'cainfo' to locate the associated IOC, then find the *.db file etc.
But if a PV is simply disconnected, how do you figure out on what IOC it was supposed to be, so you can then debug the issue?
Approaches can be as simple as adding "dbl >pv.list" to the end of the IOC startup script so you can later "grep" for record names.
A tool that's used at several sites is the Channel Finder, https://urldefense.com/v3/__http://channelfinder.github.io__;!!P4SdNyxKAPE!U5AxcYQifhwM9SIxCOImHct1Ao4xTCbVFjD5UhA-EV67Io3JWdXh15RepiFb$ , which includes a "recsync" component via which IOCs publish all their record names.
-Kay
- List all available PVs Stainer Tom via Tech-talk
- Re: List all available PVs Ralph Lange via Tech-talk
- Re: List all available PVs Stainer Tom via Tech-talk
- Re: List all available PVs Kasemir, Kay via Tech-talk
Pointing an IOC to system-level lib files for build Katie Matusik via Tech-talk
<2021>
2025
2026
Re: List all available PVs Michael Davidsaver via Tech-talk
<2021>
2025
2026
