Subject: Re: asynSetTrace
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 11 May 2021 12:30:14 +0200
Hi Petra,
First of all:
Which version of asyn are you using?
Any particular reason for using an older EPICS 7 version, not the latest release of that branch? (Not that it would change anything for this particular issue, but...)
On Tue, 11 May 2021 at 12:02, Petra Schwalbach via Tech-talk <[email protected]> wrote:
I want to use
asynSetTraceMask(portName,addr,mask)
asynSetTraceIOMask(portName,addr,mask)
I used EPICS 3.14.12.5 and I had no problems.
Now I use EPICS -7.0.3.1.
I configured my IOC like described in
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html
I add
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
to st.cmd, but nothing happens.
Does the command "help" on the IOC console show these commands? (That's always a quick check if things have been registered properly.)
Do you have an existing asyn port with that name correctly configured?
If yes to both: Are you sure that something is happening on that port? Do you have records connected that are working?
Cheers,
~Ralph
asynSetTrace Petra Schwalbach via Tech-talk
Prev: asynSetTrace Petra Schwalbach via Tech-talk
Next: Re: asynSetTrace Mark Rivers via Tech-talk
