There are some additional values for the STAT field that can’t be transmitted over CA as an ENUM (the protocol only sends the first 16 state names as shown in Tim’s graphic from MEDM), but the calc record will get their numeric values. The full list of STAT
values can be found in any of include/alarm.h, include/menuAlarmStat.h or dbd/menuAlarmStat.dbd in Base.
- Andrew
Hi Andrew,
Yes, just specify the record's stat field in one of the calc record's input fields. You'll get a number from the following list
All,
I was wondering if there was some method to compare the alarm severity, where I want to determine if one of my record’s STAT field is set to be NO_ALARM or COMM. Can that be done using something like a CALC record?
Andy
Complexity comes for free, simplicity you have to work for.
- RE: Means of comparing alarm status with a conditional in a CALC record Wang, Andrew via Tech-talk
- Means of comparing alarm status with a conditional in a CALC record Wang, Andrew via Tech-talk
- Re: Means of comparing alarm status with a conditional in a CALC record Mooney, Tim M. via Tech-talk
[info] ICALEPCS 2021 abstract submission extended to May 20th Yingbing YAN via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
