HI Adam,
On May 18, 2021, at 2:01 AM, Manoussakis, Adamandios via Tech-talk < [email protected]> wrote:
I am trying to figure out why I cannot access the front end interface of the archiver (192.168.3.50:17665/mgmt/ui/index.html) from another subnet. Locally it works perfectly fine, able to archive PVs and retrieve with
Phoebus for example or even using python. When I try to get the web page to serve up on another PC that is not on the same subnet 192.168.2.25(PC) and 192.168.3.50(Archiver) for example it seems like the request gets stuck. Some possible debugging has led
to the JS not being loaded properly on the web browsers but I have looked for anything that would block on the network and cant seem to find any issue.
The IP addresses that you are using (192.168.*.*) are in the Private IP range, and are often not routable (at least when it comes to transit
over the public internet). Do you know for sure that your routers are properly configured to pass packets between these subnets? Can you ping between them (both ways) and make some kind of a TCP connection (e.g. ssh or telnet) with devices in the other subnet?
I know nothing about the internals of the Archiver Appliance, tomcat, or the Java network stack, but it’s conceivable that something there (or even in a firewall) might also be preventing packets from the other private network from being delivered or sent.
Just an idea, I might be completely wrong though.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Re: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
- Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Re: Utilizing StreamDevice in conjunction with sockets Johnson, Andrew N. via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
