Subject: Re: How to set bo PV to zero when starting Modbus IOC
To: 高振华 <[email protected]>
Date: Tue, 25 May 2021 01:00:06 +0000
Hi Zhenhua,
The value in the database file will be replaced by the value read from the device.
There are 2 ways to force the value to zero when the IOC start up:
- Add the PV to autosave and set the value to 0 before the IOC reboots. The value in autosave will be written to the device if PINI=1.
- Put a dbpf command after iocInit which writes zero to the PV.
Sent from my iPhone
> On May 24, 2021, at 7:39 PM, 高振华 <[email protected]> wrote:
> Hi Mark,
> I tried to set BO PV to zero when starting Modbus R2-11 IOC, but failed. PINI worked, but VAL didn't work.When IOC is started, what is written to PLC is the value that has just been read.
> Can't the Modbus R2-11 driver set BO PV to zero when IOC starts?
> Best regards.
> Gao Zhenhua
> BSRF(Beijing Synchrotron Radiation Facility)
> Email:[email protected]
Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Prev: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Next: Issue with FPGA based encoder box when running with EPICS 7.0.5 Wlodek, Jakub via Tech-talk
Prev: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Next: Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
