Unfortunately, I believe what you want to do (and which seems
reasonable) is not possible.
You can work-around (if performance is not critical), e.g., by writing
a calcout device support
module that
1. fetches a copy of the entire waveform
2. modifies the target element
3. writes the modified waveform back to the waveform record
- Till
On 6/10/21 12:00 PM, Florian Feldbauer via Tech-talk wrote:
Hey all,
I have a question regarding waveform records. So far I never really
worked with waveform or any other array-type record.
The Situation is:
- Our DAQ collects the data coming from our Pixel sensor.
- Every 10s an IOC reads the stored data and fills a waveform record
with the hits (index of array = pixel, value = number of hits in the run)
- I use an image widget in Phoebus to display the hit map of the pixel
sensor
Now, for testing the sensors after bonding, we can perform charge
injections to individual pixels. We can also mask individual pixels if
they are too noisy.
As we need to always send the information for all pixels to the
sensor, I thought about using a second waveform record holding the per
pixel configuration.
Using the cursor X/Y PVs from the image widget in phoebus I could
select a pixel I want to inject a charge for testing (or I want to
mask b/c it's noisy) and get calculate the index within the waveform
record from these two PV's using a CALC record.
So now my actual question: Let's say I want to mask pixel 42, is it
possible to just write to val[41] from my config waveform record from
a CALC(OUT) record without touching the other values of the array?
Cheers,
Florian
- Re: Writing to Waveform from CALC Ralph Lange via Tech-talk
- Writing to Waveform from CALC Florian Feldbauer via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
