Subject: Re: EPICS-MODBUS plus SNC Sequencer in and IOC
To: Josh Fiddler <[email protected]>
Date: Tue, 15 Jun 2021 02:13:57 +0000
> Having configured a TCP driver in Koyo1.cmd, and checked RELEASE for the correct paths, running ./st.cmd closes silently.
Did you edit st.cmd?  The distributed version does not contain a line with #! and the name of an application.
You will need to edit st.cmd to select Koyo1.cmd rather than sim1.cmd.
Then run the test IOC from the modbus/iocBoot/iocTest directory by typing:
../../bin/linux-x86_64/modbusApp st.cmd
From: Tech-talk <[email protected]> on behalf of Josh Fiddler via Tech-talk <[email protected]>
Sent: Monday, June 14, 2021 4:54 PM
To: [email protected]
Subject: EPICS-MODBUS plus SNC Sequencer in and IOC
Hey EPICS masters,
I'm stuck. As the subject suggests, I'm trying to create an application to communicate with a DL205 plc via Modbus TCP and control via a state machine.
I've not been able to get the modbusApp testIOC running. I've followed the instructions and suggestions in the docs. Having configured a TCP driver in Koyo1.cmd, and checked RELEASE for the correct paths, running ./st.cmd closes silently.
How do I make use of the .template files to create the database for the sequencer?
Josh
[https://lh3.googleusercontent.com/pCXhB1osnZ8TglhO9_m1MnGO1UXpqIVyn3pzDiZt4StUUeysZvOKP8EQy6RDBcPzbl1ZKgblesdl_Ks6TSGci5vpDUD4a79y_-rjxZcPxpaPSiY6nez1TI-DsKu8MJVOfpHD55ln]
Josh Fiddler
Fusion Technician
+1-450-245-1065
www.f.energy<http://www.f.energy> [https://lh6.googleusercontent.com/PYvuP7XKjlBS5BrntaZuZbPM4dUb2Upc639tl3oAYdYDGMhSYrIiEcakGBN-AYJ0uH_ubwc8ofqAoAw3KNB3W4c4ozO5GUepy-6alVnrA7wZQ4hlSFPCFLNGevCqLQnT4G70rvpG]
Linkedin<https://www.linkedin.com/in/josh-fiddler/>
Re: EPICS-MODBUS plus SNC Sequencer in and IOC Mark Rivers via Tech-talk
EPICS-MODBUS plus SNC Sequencer in and IOC Josh Fiddler via Tech-talk
Prev: EPICS-MODBUS plus SNC Sequencer in and IOC Josh Fiddler via Tech-talk
Next: Re: EPICS-MODBUS plus SNC Sequencer in and IOC Mark Rivers via Tech-talk
