Subject: Re: Re: Get timestamp from another IOC
From: Zhang Yuliang via Tech-talk <[email protected]>
To: "adrian martinez" <[email protected]>
Cc: [email protected]
Date: Wed, 16 Jun 2021 22:13:33 +0800 (GMT+08:00)
Hello Adrian,
Please paste the code of record "$(Y):Timestamp_from_IOC1". Can you make sure the record "$(Y):Timestamp_from_IOC1" processed periodically or only once?
Yuliang
-----原始邮件-----
发件人:"Adrian Martinez" <[email protected]>
发送时间:2021-06-16 18:38:42 (星期三)
收件人: "Zhang Yuliang" <[email protected]>
抄送: [email protected]
主题: Re: Get timestamp from another IOC
Hello Yuliang,
I have deleted CP but It does not work. The PV "TimeStr" is still not updated.
Thanks, Adrián.
El mié, 16 jun 2021 a las 12:09, Zhang Yuliang (<[email protected]>) escribió:
Hello Adrian,
Try to delete CP in line "field(TSEL, "$(Y):Timestamp_from_IOC1.TIME CP MS")".
Yuliang
-----原始邮件-----
发件人:"Adrian Martinez via Tech-talk" <[email protected]>
发送时间:2021-06-16 18:03:22 (星期三)
收件人: [email protected]
抄送:
主题: Get timestamp from another IOC
Hello,
I'm trying to get the timestamp from another IOC (we will call it "IOC1") using the following DB records:
record(stringin, "$(user):TimeStr") {
    field(DTYP, "Soft Timestamp")
    field(INP, "@%s")
    field(SCAN, ".2 second")
record(ao, "$(user):Time"){
     field(DTYP, "asynInt32")
     field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))my_time")
record(calcout, "$(user):TimeCalc"){
     field(OUT, "$(user):Time PP")
     field(CALC, "A")
     field(INPA, "$(user):TimeStr.VAL CP MS")
     field(PINI, "YES")
At the startup of IOC2 I am able to get the timestamp from IOC1 but only once. The PV "TimeStr" doesn't update.
Can someone help me with this task?
Thanks in advance, Adrián.
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
http://sevensols.com
Adrián Martínez Múnera
Embedded Software Engineer
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
Re: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Prev: RE: FLIR camera bit depth configuration with ADSpinnaker Mark Rivers via Tech-talk
Next: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
Prev: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Next: Re: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
