Subject: Block CAPUT to not be able to modify PV value
From: Adrian Martinez via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 14 Jul 2021 15:59:31 +0200
Hello,
I need to block the setting function for some PVs. I was using SDIS and DISV fields:
record(ao, "$(user):UCrTcrLimitUsSet")
field(DTYP, "asynInt32")
field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))ucr_tcr_us")
field(VAL,  "0")
field(EGU,  "us")
field(HOPR, "10000")
field(LOPR, "0")
field(DRVH, "10000")
field(DRVL, "0")
field(SDIS, "$(user):StartUpOn.VAL CP MS")
field(DISV, "0")
info(autosaveFields, "VAL")
record(calc, "$(user):UCrTcrLimitUsRd")
field(CALC, "((A / 10^-6) / 300000000)")
field(INPA, "$(user):UCrTcrLimRd.VAL CP MS")
field(EGU,  "us")
field(DISV, "0")
This only works for the graphical user interface CSS (I am not able to modify the Pv value in the gui) but, if I use CAPUT, I can modify the PV value.
Is there any way to completely block setting function?
Thanks in advance, Adrián.
Adrián Martínez
Embedded Software Engineer
Seven Solutions
Mail: [email protected]
www.sevensols.com
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Re: Block CAPUT to not be able to modify PV value Johnson, Andrew N. via Tech-talk
Re: Block CAPUT to not be able to modify PV value Mark Rivers via Tech-talk
Prev: Re: Event Recordings -- Epics Spring 2021 Maren Purves via Tech-talk
Next: Re: Block CAPUT to not be able to modify PV value Johnson, Andrew N. via Tech-talk
Prev: Re: P4P gateway development question Michael Davidsaver via Tech-talk
