Subject: |
RE: Archiver Appliance mgmt tomcat issue |
"Manoussakis, Adamandios via Tech-talk" <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 13 Aug 2021 04:19:20 +0000 |
Thanks Murali, ive been busy getting a bunch of other things running but will need to revisit this in the future. Will try out some of your suggestions when I get a chance.
Adam
Shankar, Murali via Tech-talk
Sent: Tuesday, May 18, 2021 6:17 AM
To: [email protected]
Subject: Re: Archiver Appliance mgmt tomcat issue
>> When I try to get the web page to serve up on another PC that is not on the same subnet 192.168.2.25(PC) and 192.168.3.50(Archiver) for example it seems like the request
gets stuck.
>> Some possible debugging has led to the JS not being loaded properly on the web browsers
You can look in the mgmt's localhost access logs to see if there is a difference when loading the UI from the local machine to the PC. Both Firefox and Chrome also should
have more details in the Browser console; you should be able to see any Exceptions there.
>> I wasn’t sure about the redirectPort if that had to be changed?
Not really; not unless you plan to use HTTPS for the tomcats.
- Re: Archiver Appliance mgmt tomcat issue Shankar, Murali via Tech-talk
Re: Mark Rivers via Tech-talk
IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
<2021>
2025
2026
New sequencer release 2.2.9 Ben Franksen via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
