Hi Evan,
On Aug 13, 2021, at 10:48 AM, Daykin, Evan via Tech-talk < [email protected]> wrote:
I have just restarted a set of IOCs after puppetizing their configuration. They are accessible via a Telnet ProcServ connection, and dbpf shows everything populated and defined. However, if I try to use caget, caput,
etc. there is no connection. What are the possible causes of this? EPICS_CA_AUTO_ADDR_LIST seems to be set as “YES” and other IOCs I haven’t touched are still reachable.
Is Puppet running them inside a container? If so you need to configure that to share the host’s network (or run a CA Gateway between the host’s network and the internal container network, but I don’t really recommend doing that).
The iocsh command ‘casr 1’ will show you what the network interfaces are that the CA server is listening on and sending beacons to.
- Andreww
Complexity comes for free, simplicity you have to work for.
- IOC up, but can't connect via channel access Daykin, Evan via Tech-talk
Re: IOC up, but can't connect via channel access Johnson, Andrew N. via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
