Hi Michael,
Thanks for your reply, below you can find the requested settings. It seems that the installation added a virtual bridge.
I've tried to disable the virtual bridge; cleared iptables and checked again, without success. Ref listed settings at the end.
Initial settings
ifconfig:
enp22s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.20 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::240:9eff:fe05:a4ba prefixlen 64 scopeid 0x20<link>
ether 00:40:9e:05:a4:ba txqueuelen 1000 (Ethernet)
RX packets 2434 bytes 253208 (247.2 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 680 bytes 94609 (92.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0xdf700000-df77ffff
enp23s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 00:40:9e:05:a4:bb txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
device memory 0xdf600000-df67ffff
enp24s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 00:40:9e:05:a4:bc txqueuelen 1000 (Ethernet)
device memory 0xdf500000-df57ffff
enp25s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:40:9e:05:a4:bd txqueuelen 1000 (Ethernet)
device memory 0xdf400000-df47ffff
ens9f0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:40:9e:05:a4:b8 txqueuelen 1000 (Ethernet)
ens9f1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:40:9e:05:a4:b9 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 3650 bytes 226700 (221.3 KiB)
TX packets 3650 bytes 226700 (221.3 KiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 52:54:00:93:f0:06 txqueuelen 1000 (Ethernet)
iptables:
# Generated by iptables-save v1.8.4 on Mon Aug 16 13:11:30 2021
*filter
:INPUT ACCEPT [3148:270105]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [2259:160553]
:LIBVIRT_INP - [0:0]
:LIBVIRT_OUT - [0:0]
:LIBVIRT_FWO - [0:0]
:LIBVIRT_FWI - [0:0]
:LIBVIRT_FWX - [0:0]
-A INPUT -j LIBVIRT_INP
-A FORWARD -j LIBVIRT_FWX
-A FORWARD -j LIBVIRT_FWI
-A FORWARD -j LIBVIRT_FWO
-A OUTPUT -j LIBVIRT_OUT
-A LIBVIRT_INP -i virbr0 -p udp -m udp --dport 53 -j ACCEPT
-A LIBVIRT_INP -i virbr0 -p tcp -m tcp --dport 53 -j ACCEPT
-A LIBVIRT_INP -i virbr0 -p udp -m udp --dport 67 -j ACCEPT
-A LIBVIRT_INP -i virbr0 -p tcp -m tcp --dport 67 -j ACCEPT
-A LIBVIRT_OUT -o virbr0 -p udp -m udp --dport 53 -j ACCEPT
-A LIBVIRT_OUT -o virbr0 -p tcp -m tcp --dport 53 -j ACCEPT
-A LIBVIRT_OUT -o virbr0 -p udp -m udp --dport 68 -j ACCEPT
-A LIBVIRT_OUT -o virbr0 -p tcp -m tcp --dport 68 -j ACCEPT
-A LIBVIRT_FWO -s 192.168.122.0/24 -i virbr0 -j ACCEPT
-A LIBVIRT_FWO -i virbr0 -j REJECT --reject-with icmp-port-unreachable
-A LIBVIRT_FWI -d 192.168.122.0/24 -o virbr0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A LIBVIRT_FWI -o virbr0 -j REJECT --reject-with icmp-port-unreachable
-A LIBVIRT_FWX -i virbr0 -o virbr0 -j ACCEPT
COMMIT
# Completed on Mon Aug 16 13:11:30 2021
*security
:INPUT ACCEPT [2055:115579]
:OUTPUT ACCEPT [2268:162437]
COMMIT
*raw
:PREROUTING ACCEPT [3391:292302]
:OUTPUT ACCEPT [2271:163149]
COMMIT
*mangle
:INPUT ACCEPT [3152:270313]
:OUTPUT ACCEPT [2274:163653]
:POSTROUTING ACCEPT [2382:184751]
:LIBVIRT_PRT - [0:0]
-A POSTROUTING -j LIBVIRT_PRT
-A LIBVIRT_PRT -o virbr0 -p udp -m udp --dport 68 -j CHECKSUM --checksum-fill
COMMIT
*nat
:PREROUTING ACCEPT [1231:155805]
:INPUT ACCEPT [3:180]
:POSTROUTING ACCEPT [1023:75682]
:OUTPUT ACCEPT [1023:75682]
-A LIBVIRT_PRT -s 192.168.122.0/24 -d 224.0.0.0/24 -j RETURN
-A LIBVIRT_PRT -s 192.168.122.0/24 -d 255.255.255.255/32 -j RETURN
-A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p tcp -j MASQUERADE --to-ports 1024-65535
-A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p udp -j MASQUERADE --to-ports 1024-65535
-A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -j MASQUERADE
COMMIT
casr 1:
Starting iocInit
## EPICS R7.0.4.2-DEV
## Rev. 2021-08-10T15:08+0200
epics> casr 1
Channel Access Server V4.13
No clients connected.
CAS-TCP server on 0.0.0.0:5064 with
CAS-UDP name server on 0.0.0.0:5064
Sending CAS-beacons to 2 addresses:
192.168.0.255:5065
192.168.122.255:5065
epics>
Settings after removing virbr0 and clearing iptables
ifconfig:
RX packets 654 bytes 52760 (51.5 KiB)
TX packets 426 bytes 47582 (46.4 KiB)
RX packets 141 bytes 11468 (11.1 KiB)
TX packets 141 bytes 11468 (11.1 KiB)
iptables:
# Generated by iptables-save v1.8.4 on Mon Aug 16 13:55:49 2021
*filter
:INPUT ACCEPT [685:52841]
:OUTPUT ACCEPT [560:58709]
COMMIT
# Completed on Mon Aug 16 13:55:49 2021
*security
:INPUT ACCEPT [638:48254]
COMMIT
*raw
:PREROUTING ACCEPT [687:52921]
:OUTPUT ACCEPT [563:59377]
COMMIT
*mangle
:OUTPUT ACCEPT [565:59745]
:POSTROUTING ACCEPT [612:64332]
COMMIT
*nat
:PREROUTING ACCEPT [3:204]
:INPUT ACCEPT [3:204]
:POSTROUTING ACCEPT [77:5420]
:OUTPUT ACCEPT [77:5420]
COMMIT
-----Original Message-----
Sent: vrijdag 13 augustus 2021 20:45
To: Meeus Kris <[email protected]>; [email protected]
Subject: Re: IOC PVA on mTCA CPU requires environment variables to be set
On 8/13/21 6:49 AM, Meeus Kris via Tech-talk wrote:
> However, setting these environment variables shouldn't be required (and I never did before e.g. in wsl) since this is all localhost access.
fyi. neither CA nor PVA searches using the loopback by default.
To help understand the situation further, please provide some information
about the host network configuration ('ifconfig' or 'ip addr'), and firewall
configuration ('iptables-save' or 'nft list ruleset').
- Re: IOC PVA on mTCA CPU requires environment variables to be set Michael Davidsaver via Tech-talk
- IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
ADCameralink on Linux Дмитрий Прощенко via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
