Subject: Re: ADCameralink on Linux
To: Дмитрий Прощенко <[email protected]>
Date: Mon, 16 Aug 2021 15:13:33 +0000
Most people using PCI cameras are using Window and ADPcoWin. ADCameraLink is less well used and tested, but it should work on Linux. If you get it working please make a pull request so others can benefit from your work.
Sent from my iPhone
> On Aug 16, 2021, at 7:41 AM, Дмитрий Прощенко via Tech-talk <[email protected]> wrote:
> Hi all!
> I want to integrate pco.edge and Camera Link HS in EPICS for Linux. Is it possible to do it using areaDetector? I used the Installation guide, bit had a build error related to ADCameralink. I was able to find a Silicon Software drivers (siso-5.7.0), but I do not understand how to use drivers in the project. Should I replace siliconSoftwareSupport with siso-5.7.0 and rewrite Makefile?
> Best regards!
ADCameralink on Linux Дмитрий Прощенко via Tech-talk
Prev: Re: IOC PVA on mTCA CPU requires environment variables to be set Michael Davidsaver via Tech-talk
Next: Question about retrieve history data in archiver appliance lzfneu via Tech-talk
Prev: ADCameralink on Linux Дмитрий Прощенко via Tech-talk
