Hi Andrew,
Ok. I will try that.
Thanks!
Hi Lucas,
On Sep 1, 2021, at 4:16 PM, Lucas Russo < [email protected]> wrote:
lerwys@lerwysPC:~$ caget wave
wave 5 1 2 3 4 5
lerwys@lerwysPC:~$ caget subarr
subarr 5 2 0 0 0 0
subarr always returns an array of 5 elements, but I was trying to achieve a subArray of only 1 element. Something like:
subarr 2
Is that possible?
Try using caget -c subarr instead — unfortunately caget without a
-c option will always print the maximum number of elements that the array can hold (zero-filled after the number received), but using
-c it uses a CA get_callback() API which asks the IOC how many elements the array currently holds and shows that instead. That will be 1 so you should get what you’re asking for.
- Andrew
Complexity comes for free, simplicity you have to work for.
- subArray behavior reading just 1 element Lucas Russo via Tech-talk
- Re: subArray behavior reading just 1 element Lucas Russo via Tech-talk
- Re: subArray behavior reading just 1 element Johnson, Andrew N. via Tech-talk
Quickstart archiver appliance error frangil.ramirez via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
