Well, that gives me some interesting results.
Full dump at: https://pastebin.com/4iqDBfem
TL;DR:
> caget -d CTRL_DOUBLE SP_Cesium:Oven_Heater:ProcessValue1
Units:
> ssh elsewhere & return
Units: °
Same behavior using PowerShell and command prompt. I don’t see any change to $OutputEncoding before or after the ssh command, nor does manually setting $OutputEncoding = [System.Text.Encoding]::UTF8 make any difference. Chcp reports the
same active code page before and after ssh (437), so that doesn’t seem to be the right direction. I don’t have hexdump on windows, yet.
Greg
> caget SP_Cesium:Oven_Heater:ProcessValue1
SP_Cesium:Oven_Heater:ProcessValue1 22.855
Try
and note the 'Units'.
Also try
caget -d CTRL_DOUBLESP_Cesium:Oven_Heater:ProcessValue1 | hexdump -c
to see exactly what characters follow the "Units:"...
Fundamentally, phoebus will allow UTF-8 encoded text for the units.
-Kay
- Odd characters in temperatures showing in Phoebus Leblanc, Gregory via Tech-talk
- Re: Odd characters in temperatures showing in Phoebus Kasemir, Kay via Tech-talk
pvaPy: PvObject - odict_keys not subscriptable issue Kuldeep Joshi via Tech-talk
<2021>
2025
2026
RE: Odd characters in temperatures showing in Phoebus Leblanc, Gregory via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
