Subject: Re: Epics Archiver Appliance Storage Question
From: "Wilson, Andy \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: Abdalla Ahmad <[email protected]>, EPICS tech-talk <[email protected]>, "Manoussakis, Adamandios" <[email protected]>
Date: Tue, 12 Oct 2021 08:13:17 +0000
Hi Adam,
It appears that the storage locations are stored in the PVTypeinfo in the MySQL database, which are set in the policies.py file when you first archive a PV.
In the case of our install, the storage locations have the environment variables in them, like below, but if they are set to the literal locations in policies.py I guess they will need updating.
Snippet from database:
INSERT INTO `PVTypeInfo` VALUES ('<some_pv>,'{\"hostName\":\"<some_host>\",\"paused\":\"false\",\"creationTime\":\"2017-10-12T14:47:00.790Z\",\"lowerAlarmLimit\":\"NaN\",\"precision\":\"0.0\",\"lowerCtrlLimit\":\"-11.0\",\"units\":\"log\",\"computedBytesPerEvent\":\"20\",\"computedEventRate\":\"0.033333335\",\"usePVAccess\":\"false\",\"computedStorageRate\":\"0.6666667\",\"modificationTime\":\"2017-10-18T14:24:22.063Z\",\"upperDisplayLimit\":\"3.0\",\"upperWarningLimit\":\"-7.0\",\"DBRType\":\"DBR_SCALAR_DOUBLE\",\"dataStores\":[\"pb:\\/\\/localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_30MIN&consolidateOnShutdown=true\",\"pb:\\/\\/localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&partitionGranularity=PARTITION_DAY&hold=2&gather=1\",\"pb:\\/\\/localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&partitionGranularity=PARTITION_YEAR\"], ...
Snippet from policies.py:
# We use the environment variables ARCHAPPL_SHORT_TERM_FOLDER and ARCHAPPL_MEDIUM_TERM_FOLDER to determine the location of the STS and the MTS in the appliance
shorttermstore_plugin_url = 'pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_HOUR&consolidateOnShutdown=true'
mediumtermstore_plugin_url = 'pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&partitionGranularity=PARTITION_DAY&hold=2&gather=1'
longtermstore_plugin_url = 'pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&partitionGranularity=PARTITION_YEAR'
Cheers,
Andy
From: Tech-talk <[email protected]> on behalf of Manoussakis, Adamandios via Tech-talk <[email protected]>
Sent: Tuesday, October 12, 2021 08:21
To: Abdalla Ahmad <[email protected]>; EPICS tech-talk <[email protected]>
Subject: RE: Epics Archiver Appliance Storage Question
Thanks Abdalla, seems like it shouldn’t be too much trouble.  I have tried stopping the tomcat instances, making sure the environment variable is set correctly (I did see in the policies.py file where the paths are set).  I tried to restart the archiver appliance and also re-archived the pv (paused/deleted) but it still seems to be going to the old spot.  It looks like the file I am using is from Hans site-specific install where it was hardcoded the paths actually for sts/mts/lts.  I tried to just change the directory to see if it would work but still no success in getting the archiver to save the files in a different directory for sts.
Adam
Sent: Monday, October 11, 2021 11:43 PM
To: Manoussakis, Adamandios <[email protected]>; EPICS tech-talk <[email protected]>
Hi Adam
I think it should be easy by changing the macro variables, I think we did this before and it was working, just make sure that you have read/write permissions on the new locations otherwise all your PVs will remain in the “Appliance Assigned” state. For your 2nd question, STORAGE_TOP is optional, the three storage locations definitions are independent, it is not mandatory for the locations or mount points to share the same “STORAGE_TOP”, you can specify each store in the appropriate mount point in your setup.
If you have enough RAM on your server, it is best practice to setup the STS using a RAM disk (the tempfs filesystem), this will improve performance on data retrieval for recent periods.
Best Regards,
Abdalla Al-Dalleh
Control Engineer, SESAME
Phone: +962-788183296
Email: [email protected]
Sent: Tuesday, October 12, 2021 1:57 AM
To: EPICS tech-talk
Subject: Epics Archiver Appliance Storage Question
Hey All,
I am planning on changing where our STS MTS and LTS are stored.  Most likely will use STS MTS on the local SSD I have but wanted to move our LTS over to a NAS or some external storage.  Wanted to know if there are any pitfalls to setting this up or is at as easy as changing up these values in the archappl.conf?  Also was wondering about what STORAGE_TOP does if say my LONG_TERM_FOLDER does not share the same STORAGE_TOP directory for example?
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/Network/lts/StorageExample "
Adam
Re: Epics Archiver Appliance Storage Question Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Epics Archiver Appliance Storage Question Manoussakis, Adamandios via Tech-talk
RE: Epics Archiver Appliance Storage Question Abdalla Ahmad via Tech-talk
RE: Epics Archiver Appliance Storage Question Manoussakis, Adamandios via Tech-talk
Prev: RE: Epics Archiver Appliance Storage Question Manoussakis, Adamandios via Tech-talk
Next: Re: Epics Archiver Appliance Storage Question Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
