Hello Liang -
You need to set the variable EPICS_BASE to point to your local installation of EPICS. This should be done in the configure/RELEASE file.
(you can see that this is the problem since the path it is looking for is /configure/RULES_TOP instead of /path/to/epics/base/configure/RULES_TOP)
Cheers,
Simon Rose
Software Engineer
European Spallation Source
And when i install xxx module of synapps, i get the error.
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make: *** No rule to make target '/configure/RULES_TOP'. Stop.
- xxx moduld make error 网易邮件中心 via Tech-talk
stream install error 网易邮件中心 via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
