Subject: RE: ADLightField start LightField failed
From: Mark L Rivers via Tech-talk <[email protected]>
To: GONG Yu <[email protected]>
Date: Mon, 15 Nov 2021 20:27:33 +0000
Ø  os: windows 7 pro sp1
Ø  LightField version: 4/5.3
I am not sure what you mean by LightField 4/5.3.  Do you mean you have tried both version 4 and version 5.3?
It appears that you are running a very old version of LightField, 5.3 is from 2015.  The ADLightfield RELEASE.md file says for R2-5 (January 2018) that the version of LightField supported is 6.4.  We are currently using LightField 6.13.1 and it works fine.
You need to update to a recent version of LightField if you want to use ADLightField.
From: Tech-talk <[email protected]> On Behalf Of GONG Yu via Tech-talk
Sent: Thursday, November 11, 2021 7:36 PM
To: [email protected]
Subject: ADLightField start LightField failed
Hello,
   I installed the areaDetector and the included ADLightField intended to control the spectrometer SCT320 and CCD-PIMAX4 512 (both are Princeton Instruments and can be controlled by LightField which have been tested). When I execute the command:
..\..\bin\windowns-x64\LightFieldApp.exe st.cmd
then the software LightField page start, but a dialog pops up said: LightFiled has stopped working.
After then, another dialog pops up: AddInProcess.exe has stopped working. I Look into the detail of the description on it, I found System.DllNotFoundException. I do not know if this error caused by some dll files missing, if so which dll files I missed and how to solve it?
After closing the dialogs (which prompts AddInProcess.exe has stopped working), in the command window that show information related to EPICS there prompts: System.Runtime.Remoting.RemotingException: Failed to read from an IPC Port. The pipe has been ended...
I donnot know how to solve these situations, and need helps.
EPICS base version: 7.0.3.1
areaDetector version: R3-11 (inclued in synApps 6_2_1)
st.cmd is listed below:
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/LightFieldApp.dbd")
LightFieldApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "13LF1:")
# The port name for the detector
epicsEnvSet("PORT",   "LF1")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "512")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "512")
# The maximum number of time seried points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
LightFieldConfig("$(PORT)", "", 0, 0)
asynSetTraceIOMask("$(PORT)",0,2)
#asynSetTraceMask("$(PORT)",0,255)
dbLoadRecords("$(ADLIGHTFIELD)/db/LightField.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from the LightField driver.
NDStdArraysConfigure("Image1", 5, 0, "$(PORT)", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=int16,FTVL=SHORT,NELEMENTS=1500000")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd
set_requestfile_path("$(ADLIGHTFIELD)/lightFieldApp/Db")
iocInit()
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=$(PREFIX)")
宫宇 (GongYu)
Beijing Synchrotron Radiation FacilityInstitute of High Energy Physics, CAS
19B YuquanLu, Shijingshan District, Beijing, 100049
Phone: +86-10-88235981
ADLightField start LightField failed GONG Yu via Tech-talk
Prev: RE: Help with Blackfly FLIR/PointGrey Camera Mark L Rivers via Tech-talk
Next: disk space / network monitor in iocStats? Pearson, Matthew R. via Tech-talk
Prev: ADLightField start LightField failed GONG Yu via Tech-talk
Next: Access motor controller target positions of other axes in asynMotorAxis::move Laurenz Rettig via Tech-talk
