Subject: Re: ADEiger/Filewriter question
From: Mark L Rivers via Tech-talk <[email protected]>
To: John Dobbins <[email protected]>
Date: Sat, 20 Nov 2021 21:48:12 +0000
You are using the $id to increment the file number within a scan? But you want to increment the base file name as well? That seems like a reasonable feature request.
It seems like setting AutoRemove should fix the issue, but I’d be interested to hear if it does.
Sent from my iPhone
On Nov 20, 2021, at 3:41 PM, John Dobbins <[email protected]> wrote:
Mark,
Our solution was to change EIG500:EIG:FWNamePattern with each scan. (Is there a way to make this auto-increment?)
Also, FWAutoRemove = Yes should solve the problem?
I was just trying to understand where I might have gone astray, something I have a knack for.
John
Sent: Saturday, November 20, 2021 4:07 PM
Cc: [email protected] <[email protected]>
Hi John,
I don’t think that what you are doing has ever been tested. It works on ADPilatus, where the driver checks the file creation time. But I don’t think that check is done in ADEiger. Even if it were done, if the clocks are not synchronized it won’t work. Can you use the Stream interface instead as a workaround?
Sent from my iPhone
On Nov 20, 2021, at 2:55 PM, John Dobbins via Tech-talk <[email protected]> wrote:
All,
The ADEiger documentation reads:
"The generated files will be downloaded either if DataSource is set to FileWriter or if SaveFiles is set to Yes. Files are downloaded as soon as they are available."
What does "as soon as they are available" mean, i.e. how is availability determined?
I asked because we encountered a problem in which the IOC was downloading stale files from the previous acquisition.
The PV, EIG500:EIG:FWAutoRemove was set to 'No', and EIG500:EIG:FWNamePattern was constant, so with each acquisition the files get overwritten on the DCU. The IOC was grabbing old files before they got overwritten.
There was a time discrepancy between the DCU and the IOC. Would that lead the IOC to determine the files were available when in fact they weren't.?
ADEiger version = 2.5
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADEiger/Filewriter question John Dobbins via Tech-talk
Re: ADEiger/Filewriter question Mark L Rivers via Tech-talk
Re: ADEiger/Filewriter question John Dobbins via Tech-talk
Prev: Re: ADEiger/Filewriter question John Dobbins via Tech-talk
Next: Re: Re: Re: Re: A problem with modbus reading floating point numbers 高振华 via Tech-talk
Next: Phoebus Image Decompression Smith, William via Tech-talk
