Hi Will,
> Does Phoebus image viewer work with area detector compressed images sent over PV access? I.E can it read the compression type from the PV access protocol and perform the decompression?
At this time, regrettably, no. The relevant code is in https://github.com/ControlSystemStudio/phoebus/blob/master/core/pv/src/main/java/org/phoebus/pv/pva/ImageDecoder.java
In principle, it's straight forward to add something like `struct.get("compression")` to determine how the data is compressed, and to then un-compress the `value`.
If you have some actual test data and information on how to decode the compressed image, please go ahead and implement it.
Kay
- RE: Phoebus Image Decompression Mark L Rivers via Tech-talk
- Phoebus Image Decompression Smith, William via Tech-talk
Control Systems Developer + DevOps Role at Fusion Startup Josh Fiddler via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
