Subject: Re: Alternative to EPICS Gateway
From: Gerrit Kühn via Tech-talk <[email protected][email protected], ov>@aps.anl.gov
To: [email protected]
Date: Wed, 24 Nov 2021 09:34:03 +0100
On Tue, 23 Nov 2021 07:28:06 -0800
Michael Davidsaver via Tech-talk <[email protected]> wrote:
> Also, remember that search of TCP is possible, so eg. a pair of
> gateways with a limited tunnel (SSH or VPN) can bridge between
> logically separated networks.  (cf. $EPICS_CA_NAME_SERVERS)
If you have a VPN in bridge-mode, it will even work without any
additional setup. We have been successfully using tinc for this kind of
setup (other vpn solutions supporting bridge-mode should work, too).
cu
  Gerrit
Gerrit Kühn
Max Planck Institute for Gravitational Physics
(Albert Einstein Institute)
Callinstraße 38
D-30167 Hannover, Germany
Email: [email protected]
Alternative to EPICS Gateway Wilkins, Stuart via Tech-talk
Re: Alternative to EPICS Gateway Michael Davidsaver via Tech-talk
Prev: Re: Finding the server where a PV's IOC is located Ralph Lange via Tech-talk
Next: ODP: Failed connection using e3-s7plc to Siemens S7-1500 Mateusz Nabywaniec via Tech-talk
Prev: Re: Alternative to EPICS Gateway Michael Davidsaver via Tech-talk
Next: Finding the server where a PV's IOC is located Sobhani, Bayan via Tech-talk
