Subject: RE: ADPilatus $(P)$(R)FileFormat ?
To: John Dobbins <[email protected]>
Date: Tue, 30 Nov 2021 17:22:22 +0000
Hi John,
You are correct to be confused.
The FileFormat PV comes from the asynNDArrayDriver base class, and is documented here:
https://areadetector.github.io/master/ADCore/NDArray.html#asynndarraydriver
However, that PV is not used in the ADPilatus driver, and so does not belong on the OPI screens.  I have removed the PVs from the OPI screens and tweaked the layout.  I have pushed to the master branch of ADPilatus on Github.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, November 30, 2021 10:52 AM
To: [email protected]
Subject: ADPilatus $(P)$(R)FileFormat ?
I want to write cbf files from a Pilaus detector.  I understand this is selected by the choice of the file extension in $(P)$(R)FileTemplate.
On the MEDM screen I also see a $(P)$(R)FileFormat menu mux which offers the choices TIFF | Invalid.
This PV isn't mentioned in the documentation:
So, I am a little confused. Thanks.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADPilatus $(P)$(R)FileFormat ? John Dobbins via Tech-talk
Prev: ADPilatus $(P)$(R)FileFormat ? John Dobbins via Tech-talk
Next: Dropdown menu problem when running Phoebus inside a Docker container Oscar Ibañez via Tech-talk
