Subject: asynUSBTMC communications issue
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Wed, 1 Dec 2021 21:24:33 +0000
Mark,
I’m trying to use the asynUSBTMC driver to connect to some SCPI USB devices.  I’ve got a Keithley 3390 Waveform generator, a B&K 9130B Power Supply and a B&K 8600B Electronic load all connected by USB.
All of the units work properly with the supplied LabView extensions on my Windows system.
Using the Asyn driver however, I can send most any query function that I want and get a proper response.  Send a command (even something like *RST or *CLR), and the device reports an invalid termination character on the Keithley, and the B&K’s just fail to answer or lock up.
I’ve tried CR LF, CR, LF, NL as terminations, and they all provide the same problems.
Any ideas on where to start looking?
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
Re: asynUSBTMC communications issue Eric Norum via Tech-talk
Prev: Re: CSS (Eclipse and Phoebus) super slow on a server with multiple users Michael Davidsaver via Tech-talk
Next: Re: asynUSBTMC communications issue Eric Norum via Tech-talk
Prev: Re: Dropdown menu problem when running Phoebus inside a Docker container Michael Davidsaver via Tech-talk
