Subject: Re: PyDevice and an IOC
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 8 Dec 2021 09:05:07 +0100
Hey Josh,
Looking at your g++ call your IOC does not get linked against libpython3.8 which explains the undefined references to python bindings.
Can you execute the command `$(PYTHON_CONFIG) --ldflags --embed | sed 's/-[^l][^ ]*//g' | sed 's/-l//g'` by hand and check the output?
It should look like this:
$> python3-config --ldflags --embed | sed 's/-[^l][^ ]*//g' | sed 's/-l//g'
 python3.9 crypt pthread dl  util m m
HTH Florian
On 12/8/21 2:48 AM, Josh Fiddler via Tech-talk wrote:
This is for Klemen Vodopivec the author of `PyDevice`
1) thanks for making this
2) I'm having some issues getting a simple ioc to build with pydev support
I'm using a Raspberry Pi and linux-arm as the host architecture
for specific reasons: using EPICS base 3.15.6, python 3.8.10 on ubuntu for arm64 in a docker container
The module itself builds alright. and the testing ioc runs just fine
When I create a basic IOC, with makeBaseApp.pl using the ioc template,
adding the lines as indicated:
analogCtrlIOC_DBD += pydev.dbd
analogCtrlIOC_LIBS += pydev
SYS_PROD_LIBS += $(shell $(PYTHON_CONFIG) --ldflags --embed | sed 's/-[^l][^ ]*//g' | sed 's/-l//g')
with the RELEASE file for the IOC pointed at the location of the support module
with `make` i get
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE             -DUNIX  -Dlinux     -O3 -g   -Wall            -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/epics/base/include/compiler/gcc -I/epics/base/include/os/Linux -I/epics/base/include        -c ../analogCtrlIOCMain.cpp
/bin/sh: 0: Illegal option --
/usr/bin/g++ -o analogCtrlIOC  -L/epics/analogCtrlIOC/lib/linux-arm -L/epics/base-3.15.6/lib/linux-arm -L/epics/support/PyDevice/lib/linux-arm -Wl,-rpath,/epics/analogCtrlIOC/lib/linux-arm -Wl,-rpath,/epics/base-3.15.6/lib/linux-arm -Wl,-rpath,/epics/support/PyDevice/lib/linux-arm           -rdynamic            analogCtrlIOC_registerRecordDeviceDriver.o analogCtrlIOCMain.o    -ldbRecStd -ldbCore -lca -lCom -lpydev
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `Py_InitializeEx'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyLong_AsLong'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyBool_Type'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `_Py_TrueStruct'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyType_IsSubtype'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyUnicode_AsASCIIString'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyEval_RestoreThread'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `_Py_NoneStruct'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyDict_SetItemString'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyList_Size'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyFloat_AsDouble'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `Py_Finalize'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `_Py_Dealloc'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyList_GetItem'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyErr_Clear'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `Py_IncRef'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyRun_StringFlags'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `Py_DecRef'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyDict_New'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyErr_SetString'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyBytes_AsString'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyExc_TypeError'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyEval_SaveThread'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `_Py_FalseStruct'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyEval_GetBuiltins'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyObject_IsTrue'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyModule_Create2'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyErr_Occurred'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyFloat_Type'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyArg_UnpackTuple'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyErr_Print'
/usr/bin/ld: /epics/support/PyDevice/lib/linux-arm/libpydev.so: undefined reference to `PyImport_AppendInittab'
collect2: error: ld returned 1 exit status
make[3]: *** [/epics/base/configure/RULES_BUILD:204: analogCtrlIOC] Error 1
make[3]: Leaving directory '/epics/analogCtrlIOC/analogCtrlIOCApp/src/O.linux-arm'
make[2]: *** [/epics/base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
make[2]: Leaving directory '/epics/analogCtrlIOC/analogCtrlIOCApp/src'
make[1]: *** [/epics/base/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory '/epics/analogCtrlIOC/analogCtrlIOCApp'
make: *** [/epics/base/configure/RULES_DIRS:84: analogCtrlIOCApp.install] Error 2
root@daq-pi-002:/epics/analogCtrlIOC#
PYTHON_CONFIG is set for python3
any thoughts?
Josh
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: PyDevice and an IOC Josh Fiddler via Tech-talk
Prev: Re: How to put the contents of a file in a waveform record Shuei YAMADA via Tech-talk
Next: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Prev: PyDevice and an IOC Josh Fiddler via Tech-talk
Next: Re: PyDevice and an IOC Josh Fiddler via Tech-talk
