Hi Kaz,
I just power-cycled our USB camera and now arv-tool-0.8 finds it on Centos8.
[epics@viper aravis]$ arv-tool-0.8
PointGrey-010AA71D (USB3)
Allied Vision Technologies-GC1380CH (02-2143A)-02-2143A-06039 (164.54.160.49)
Allied Vision Technologies-GC1380H (02-2142A)-02-2142A-06110 (164.54.160.57)
Allied Vision Technologies-GC1380H (02-2142A)-02-2142A-06178 (164.54.160.58)
Allied Vision Technologies-GT1380 (02-2604A)-02-2604A-07008 (164.54.160.104)
Allied Vision Technologies-Manta G-507C (E0022705)-50-0503419258 (164.54.160.21)
Allied Vision Technologies-Manta_G-146C (E0020011)-50-0503317598 (164.54.160.62)
This is uname –a on that system:
[epics@viper aravis]$ uname -a
Linux viper 4.18.0-147.5.1.el8_1.x86_64 #1 SMP Wed Feb 5 02:00:39 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
I just tried running arv-tool on a Centos8 system with a FLIR GS3 USB camera installed. I got this error, even running as root.
[root@viper epics]# export LD_LIBRARY_PATH=/usr/local/lib64
[root@viper epics]# /usr/local/bin/arv-tool-0.8
Failed to open device '-': Failed to claim USB interface to '::'
I can normally run that camera with ADSpinnaker with no problem. Right now it won't start, and I think the camera needs to be power-cycled. I am not at the lab to do that. So
I am not sure if the arv-tool error is due to the camera issue or something else.
Is the version of aravis that you are using built with the USB3 support enabled?
Good point, and I did not install aravis udev rules yet.
However, when arv-tools is run as root, it does not detect the USB3 camera either.
[root@xf11id-m3 ~]# arv-tool-0.8 -d all
[11:52:14.710] 🅸 interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
[11:52:14.710] 🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.11.1 (192.168.11.255)
[11:52:14.710] 🅸 interface> [GvDiscoverSocket::new] Add interface 10.69.24.152 (10.69.24.255)
[11:52:14.711] 🅸 interface> [GvDiscoverSocket::new] Add interface 10.66.83.36 (10.66.83.255)
[11:52:14.711] 🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.122.1 (192.168.122.255)
[11:52:14.712] 🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly
BFLY-PGE-50S5C-18457368' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:19:a3:18'
BFLY-PGE-50S5C-18481534' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:1a:01:7e'
Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368 (192.168.11.11)
Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534 (192.168.11.12)
Something else is missing on RedHat...
Do you have the aravis udev rules installed so that non root accounts can actually see the usb3 hardware?
On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Monday, December 13, 2021 12:00 PM
To: [email protected]
Subject: arv-tools not detecting USB3 camera
I have a USB3 Grasshopper3 GS3-U3-51S5C camera that arv-tools-0.8 is not detecting.
The GS3-U3-51S5C supports
USB3 Vision v1.0,
{Aravis detects only my GigE cameras:}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8
{arv-tools with options does not list usb camera either}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8 -d all
[15:02:46.093] ?? interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
{The camera shows up in libusb and /dev/bus/usb, but is not found by arv-tool:}
kgofron@xf11id-m3:/epics/iocs/cam-aravis1$ lsusb
Bus 002 Device 003: ID 1e10:3300 Point Grey Research, Inc.
kgofron@xf11id-m3:/epics/iocs$ ls /dev/bus/usb/002/003
{USB camera is on bus 002 device 003}
kgofron@xf11id-m3:/dev/bus/usb/002$ usb-devices
T: Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 3 Spd=5000 MxCh= 0
D: Ver= 3.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS= 9 #Cfgs= 1
P: Vendor=1e10 ProdID=3300 Rev=00.00
S: Manufacturer=Point Grey Research
S: Product=Grasshopper3 GS3-U3-51S5C
C: #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=896mA
I: If#=0x0 Alt= 0 #EPs= 2 Cls=ef(misc ) Sub=05 Prot=00 Driver=(none)
I: If#=0x1 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=01 Driver=(none)
I: If#=0x2 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=02 Driver=(none)
USB support is installed:
Any suggestions about this problem?
