1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AW: Photonic Science X-ray FDS camera
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Wed, 15 Dec 2021 10:18:44 +0000
Hi Mark, Cobb,
I also found the ADPSL module. But from this ~7 year old tech-talk I understood that the ADAravis module is more feasible for cameras from PS.
@Mark: on this Web site:
https://photonicscience.com/oem/
under Camera Design Capabilities there is the point “Genicam compliant interface, Camera Link interface”. This is why I assume that by now they are offering the Genicam interface. But of course this has to be discussed with PS prior to any purchase.
However, in any case (with Genicam or PSLViewer) I think the camera will not work plug-and-play with EPICS, at least not with every feature. If we decide to test one, I will let you know by asking questions about ADAravis/ADPSL 😉
Thanks!
Michael
Von: Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>
Gesendet: Dienstag, 14. Dezember 2021 16:55
An: [email protected]; Sintschuk, Michael <[email protected]>; Mark Rivers <[email protected]>
Betreff: Re: Photonic Science X-ray FDS camera
Hi Michael,
I have tested a Photonic Science Genicam compliant camera a long time ago. It worked after a fashion but had some quirks that I can't remember off the top of my head. I think it used the Pleora GigE Vision Embedded Interface. If they are using this, it should work with ADAravis, but the features will need testing to make sure they have been implemented properly.
We also had another camera that used the PSLViewer that Mark describes. It did not work well.
Tom
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 14 December 2021 15:43
To: [email protected] <[email protected]>; Sintschuk, Michael <[email protected]>
Subject: Re: Photonic Science X-ray FDS camera
Hi Michael,
areaDetector does have a driver for Photonic Science cameras: https://github.com/areaDetector/ADPSL
This is from the documentation:
The interface to the detector is via a TCP/IP socket interface to the PSLViewer program that PSL provides. Before starting the areaDetector software the following needs to be done:
    • Run the PSLViewer program
    • Open the Tools/Server control window
    • Select a PORT. The default is 50000. This port must be used in the drvAsynIPPortConfigure command in the areaDetector startup script.
    • Press the Start server button.
The only description I could find on their Web site about software is this single sentence:
A device server driver control allows remote aquisition through existing GUI interface.
This leads me to think that they still do not provide an SDK for controlling their cameras, and still just use a socket interface to their standalone GUI program.  I don't see anything to indicate that the cameras have a GenICam interface.
I had issues in the past where they changed the API of their socket server, requiring non-backwards compatible changes to the ADPSL driver.
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Tuesday, December 14, 2021 7:31 AM
Subject: Photonic Science X-ray FDS camera
Hi all,
is anyone using a recent FDS Detector from Photonic Science with EPICS?
Assumed that the vendor can deliver this camera with a Genicam interface, the ADAravis module could probably handle it. But prior to the purchase of this camera, I would like to know if someone has any experience with it.
Best regards,
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
[email protected]
Re: Photonic Science X-ray FDS camera Mark Rivers via Tech-talk
Photonic Science X-ray FDS camera Sintschuk, Michael via Tech-talk
Re: Photonic Science X-ray FDS camera Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
Next: Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Photonic Science X-ray FDS camera Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: Photonic Science X-ray FDS camera Mark Rivers via Tech-talk
