Subject: RE: Reliability of caput
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Dec 2021 02:33:51 +0000
Hi Lewis,
Sorry if I wasn't clear. Basically if I run both caput commands with no wait period in between, will I expect to see 100 in A and 200 in B when I run caget.
A and B are separate records. There is no forward linking between them. They are the only records in the database file and are both passive.
-----Original Message-----
Sent: Monday, December 20, 2021 6:31 PM
To: Wang, Andrew <[email protected]>
Subject: Re: Reliability of caput
On 12/21, Wang, Andrew via Tech-talk wrote:
> Quick question.
> Suppose I have two analog input records called "A" and "B" on which I would like to do caput. If I have a bash script containing the following code:
> caput A 100
> caput B 200
> Will that give sufficient time for caput to respond?
Respond to what?  What do you mean by "respond"?
> Or should there ideally be a "delay" between each caput. The reason why I ask is because within the sequencer, we do something similar, but with pvPut, and sometimes we see that "B" does not get updated with a new value.
How are A and B related?
Lewis
Re: Reliability of caput J. Lewis Muir via Tech-talk
Reliability of caput Wang, Andrew via Tech-talk
Prev: Re: Reliability of caput J. Lewis Muir via Tech-talk
Next: Re: Reliability of caput J. Lewis Muir via Tech-talk
